Webster Mag Output Concern
this thread has 2 replies and has been viewed 2402 times
Old 08-10-2005, 05:53:02 PM
Tom Herd Tom Herd is offline
Default Webster Mag Output Concern
I have a 1.5hp Hercules engine with a one magnet Webster magneto - low tension type. Sometimes, with great effort I get it started, no crank, just pulling on the flywheels until I pass out.
The other day, when it was acting up, I connected a batter and coil to it and it fired up right away. Then I reconnected the magneto and it ran fine.
**** My theory is the magneto may be weak and not putting out the proper voltage: Enough to keep it running, but not enough to start it. Would getting it remagnetized solve the start up problem?
Old 08-10-2005, 08:57:46 PM
Elden DuRand's Avatar
Images: 6
Default Re: Webster Mag Output Concern
Tom:
Your problem could be weak magnets but also could be too little "cocking" of the mag before it trips. Also, the bearings in the mag could be loose. Also, the hammer adjustment could be off.
The hammer adjustment is the screw that the mag arm hits on the ignitor. There should be just a little clearance (.015" or so) when the mag is at rest. If there is too much clearance, the mag has passed it's maximum current point before the ignitor contacts open. If too little clearance, the opposite happens.
Good luck and remember that this advice is worth perzackly whatcher payin' fer it.
Take care - Elden
Old 08-12-2005, 08:13:34 AM
Neale Behm Neale Behm is offline
Images: 2
Tom,
Has it always been this way?
I was having starting problems with a Webster/Ignitor Stover and found that the "fixed" contact wasn't tight and it had turned slightly. After checking the outside adjustments as Elden has suggested take the ignitor assembly out and have a look at what's going on with them. Also, you could have some carbon build up that's trying to short out across the mica insulator tube or washers.
Thanks Harry
No output from an old generator... Skip Essigmann Generators & Motors General Discussion 14 03-14-2010 01:44:55 AM
20 ES no build up of AC output rhacker Onan Generators 1 01-17-2008 01:12:52 AM
Webster Inverted Gas Engine - Webster Mfg Co David Sundry Antique Gas Engine Discussion 3 01-15-2007 02:30:40 PM
DJE Output Wiring Jonathan Onan Generators 46 08-18-2005 10:22:06 AM
No output, AC generator Arthur Generators & Motors General Discussion 1 02-24-2005 12:12:49 PM
