Magnet charging--i need to get this straight
this thread has 8 replies and has been viewed 2530 times
Old 08-14-2005, 11:57:21 AM
Ihorse Ihorse is offline
Default Magnet charging--i need to get this straight
On Magnet charging--I need to get this perfectly clear!! I determine the poles on the magnet---I have already have the charger marked for poles--take the magnets off the mag-[KW-hi-bar] one at a time and charge them by putting them on the charger opposite poles for a couple bursts of about 10 seconds ----tap the magnets lightly while charging--the magnets go on the charger -with the north on the magnet to the south on the charger!--if this is correct----say yea!!--if not, tell me in understandable terms [EXACTLY] how to .
this is the only mag I have like this--I would like to keep it.
thanks d,j,
Old 08-14-2005, 12:40:03 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Images: 5
Default Re: Magnet charging--i need to get this straight
yea, that is what the instructions on mine say but nothing is mentioned about tapping on the magnets while charging. My instructions say 20 seconds on 20 off for three cycles. I hope this helps
Old 08-14-2005, 12:55:09 PM
Images: 311
Tapping on the magnet supposedly gets those molecules excited so that they will more easily align themselves with the magnetic field. I suppose you could warm their little bodies and accomplish the same thing.
Anyway, BEFORE you remove the magnet from the charger, you need to attach a KEEPER and remove the keeper only after you've placed the magnet back onto the magneto. Actually, it's much easier to charge the entire magneto on the charger. You can use extra chunks of iron to assist with the path.
-- Harry Engines Videos Photos
Old 08-14-2005, 03:43:48 PM
John Ledbetter's Avatar
John Ledbetter John Ledbetter is offline
2 Engine John
Images: 25
I was told years ago by a very good magneto mechanic that it is not necessary to remove the magnets from the magneto in order to recharge them. I have recharged a number of magnetos this way with very good results
http://2enginejohn.blogspot.com
Old 08-14-2005, 03:51:57 PM
Images: 5
I forgot to mention the armature needs to be insulated "held up" with a couple of pieces of wood or plastic not down as the previous photo shows. I am speaking of a wico mag.
Old 08-14-2005, 07:19:50 PM
Images: 311
I've not had to monkey with blocking the armature up when I charge a Wico. When I push the charger button, the Wico armature JUMPS up off the frame anyway!
Old 08-14-2005, 11:38:22 PM
Exclamation Re: Magnet charging--i need to get this straight
For best results, if possible, charge magnets on mag. Charge nested magnets as a group. If you charge individually, and one magnet is weaker, it will draw down the charge on the others. The weaker magnet acts like one that is reversed, it will cause the others to weaken. Make sure to keep a keeper on the magnets until the mag is fully assembled. While charger is on, tap magnets lightly with a brass hammer (do not use steel!) Good luck
Old 08-15-2005, 01:43:51 PM
boblester40 boblester40 is offline
When i charge magnetos i allways do it with the magnets on the magneto, I dont bother with the tapping with a hammer as it sticks to the magneto and due to the strength of the field, suppose you could do it with a brass or copper hammer though?, most inportant is to get as much surface contact between the pole pieces and the magneto make sure there are no un even surfaces on whatever blocks on metal you use to make up the gaps.
happy zapping
Old 08-15-2005, 10:57:22 PM
Roger Kirschenman Roger Kirschenman is offline
What does a iron melecule look like? If it can move in the magnet you should be abel to see it, i would think.
Webster Magnet charging Jim Cook Magnetos, Ignition Coils and Spark Plugs 5 10-19-2007 08:30:58 AM
Straight Pipes Yes Or No? Jordan Antique Gas Engine Discussion 21 08-28-2006 01:19:18 PM
Wico EK magnet charging Tanner Remillard Antique Engine Archives 3 08-06-2003 09:49:32 AM
Magnet Charging Larry Kastens Antique Engine Archives 2 02-24-2003 10:49:59 PM
AB 33 Magnet Charging Thomas Ross Antique Engine Archives 2 10-12-2001 09:52:59 PM
