T-Coil
this thread has 8 replies and has been viewed 1055 times
Old 08-16-2005, 09:53:00 AM
Bob Fultz Bob Fultz is offline
Images: 4
Default T-Coil
What's your opinion of using a resistor plug on a T-coil or will it over load the coil?
Old 08-16-2005, 11:33:55 AM
Elden DuRand's Avatar
Elden DuRand Elden DuRand is online now
Images: 6
Default Re: T-Coil
Bob:
No.
Take care - Elden
http://home.cybertron.com/~edurand
Old 08-16-2005, 01:15:48 PM
Images: 4
Default Re: T-Coil
Sorry I didn't grab the answer. (1) Don't use them or (2) It won't hurt the coil. Thanks....Bob
Old 08-16-2005, 03:21:24 PM
Default Re: T-Coil
Bob, I don't know about the damage to a resistor plug. My question is why do you need to use a restistor plug? Enlighten us a little more on the plug use. Joe Morris
Old 08-16-2005, 04:19:39 PM
Chuck Woycke Chuck Woycke is offline
Default Re: T-Coil
i think they use res. plugs to dampem the static electricy so you will not hear it on your radio.years ago the plug wires had copper wires with regular plugs that made your speakers crackel.so they came out with resistor plugs.in 1974 gm came out with their electronic ignition (hei) they switched to 7-8mm wires with carbon or graphite cores that replaced the resistor plugs.on my 1974 R90s bmw motorcycle they use resistor end caps in the plug wires .some coils are made to use resistors in their circuits to protect the coils-chuck
Old 08-16-2005, 05:16:24 PM
Mike Monnier's Avatar
Hoarder
Default Re: T-Coil
Chuck is correct, the only reason for resistor plugs is to cut down on EMI. Even the plugs you buy for your lawnmower these days are resistor plugs. I'm not sure why since there aren't any electronic devices on a 4hp pushmower.
Bob, are you using one of the pipe thread adapters to use a 14mm plug in your engine? Just curious as to how you could end up with a resistor plug in one of these old engines.
Old 08-16-2005, 06:21:29 PM
Images: 4
Default Re: T-Coil
I read where you could use adapters in a T model Ford. The plug they called for is a 14mm Bosh resistor plug. I was wandering if the plug would damage the coil. Ford states not to set the plug gap over .30 The old Champion a35 would carbon up quickly. Thanks for the help...Bob
Old 08-16-2005, 06:26:15 PM
Exclamation Re: T-Coil
Besides lowering the EMF, Resister plugs fire at a higher voltage - needed to light off the new-fangled unleaded gas. at a leaner mixture. If you are seeking radio noise suppression - forget it! The noise emanated by the timing sparker on the T coil itself will drown any signal generated by the plug by a 1,000 times! If you need the higher ignition temp, say for propane or unleaded usage, a resister plug won't hurt the coil. After all, they used to sell spark -intensifiers! All they were was an air gap in the Hi-tension circut. This increased secondary voltage resistance, and created a hotter spark. (the bigger the gap - the higher the voltage needed to fire!)
Old 08-16-2005, 06:47:57 PM
Images: 6
Red face Re: T-Coil
Bob:
Sorry! I think I had my terseness control turned up a bit too far.
Resistor plugs won't hurt a "T" coil.
jAlso, there's no reason why you can't use 'em if you have a hot coil.
Take care - Elden
Interesting coil find: The Chief Super Ignition Coil packrat56 Antique Gas Engine Discussion 3 09-14-2007 09:16:19 AM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
coil carl knissel Antique Engine Archives 5 06-18-2004 08:05:22 AM
What? Coil? David Greenwalt Antique Engine Archives 14 02-02-2002 08:12:02 AM
Have You See A K&W Coil Like This??? Michael Antique Engine Archives 1 10-25-2000 08:19:00 AM
