Maytag/Briggs check valve
this thread has 13 replies and has been viewed 1820 times
Old 08-17-2005, 07:17:33 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Images: 72
Photo Maytag/Briggs check valve
I just cant seem to find the right position to mount this New Lunkenheimer Vertical Ball Check Valve in my Maytag or on my Briggs. Any ideas?
I Get My Corn From A Jar
Old 08-17-2005, 07:32:12 PM
Rich Martz's Avatar
Rich Martz Rich Martz is offline
Images: 23
Default Re: Maytag/Briggs check valve
That check goes right before the Knudson valve.
Old 08-17-2005, 08:06:50 PM
ldj1002 ldj1002 is offline
No wonder! it's way too small.
Old 08-17-2005, 09:18:50 PM
Neale Behm Neale Behm is offline
Images: 2
Sure glad I'm not feeding the engine that uses that!!!
Old 08-17-2005, 09:29:01 PM
Images: 72
It drinks Coca Cola only $2.50 a 12 Pack.
Old 08-17-2005, 10:01:38 PM
David Greenwalt David Greenwalt is offline
Just set the Maytag on top of a 55 gallon drum and drop it down in that, you'll be able to run for the next 20 years or so. David.
Old 08-19-2005, 12:58:29 AM
Mike in NC's Avatar
Images: 64
Rich, I thought that went before the Kanuter Valve!!
Old 08-19-2005, 11:15:21 AM
Elden DuRand's Avatar
Images: 6
Exclamation Re: Maytag/Briggs check valve
Naw, Mike!
The Knauter valve goes just to the left of the Feeblevetzer pivot arm and underneath the frammis frame.
You gotta be careful of the assembly of the fronix tabulator because aggregiousness could occur.
Saying for the day: Eschew Obfuscation
Last edited by Elden DuRand; 08-19-2005 at 11:17:33 AM. Reason: The post was too bycrudjenous and had to be excalpatated.
Old 08-19-2005, 06:43:57 PM
Alan in KY
hey andrew bring it with you when you come to renfro valley rich ,neale ,and i will be able to get it to fit your engine we will use only the best duct tape available to install it on your maytag
Old 08-19-2005, 07:11:26 PM
Images: 6
Alan:
When's the Renfro Valley show? I -might- be able to make it.
Take care - Elden
http://home.cybertron.com/~edurand
Old 08-20-2005, 06:39:20 AM
Alan in KY
the southeastern ky antique gas engine and tractor show will be at renfro valley sept. 30-thru oct 2nd 0.F.E.S will be there evryone welcome look me up if you make eldon ill be there from thurs till the last cat is hung on sun lol alan
Old 08-20-2005, 11:32:49 AM
Images: 72
Elden: That might be true, But isn't it dangerously close to the radiator belt? and what about the heat from the muffler bearing?
Old 08-20-2005, 12:31:08 PM
Images: 6
Alan:
If the phramgulator doesn't seize up, I'll try to be there.
Always like to harrass those OFES guys!
Take care - Elden
Old 08-20-2005, 12:34:05 PM
Images: 6
Thumbs down Re: Maytag/Briggs check valve
Andrew:
Now, don't try that fast talkiin city slicker stuff on me!! Anyone knows that the Feeblevetzer doesn't connect to the radiator belt. It goes to the kingpin crown!
Whaddya think - I came on a truckload of punkins or somethin'???!!
Take care - Elden
Briggs 5S check valve (again) Chris Kirk Antique Engine Archives 3 04-04-2003 05:27:33 PM
Briggs 5S check valve Chris Kirk Antique Engine Archives 3 03-23-2003 01:37:09 AM
Top Hat Check Valve Ralph Leonard Antique Engine Archives 6 02-27-2003 08:22:18 PM
check valve BobRR Antique Engine Archives 7 01-10-2003 03:43:36 PM
Check Valve Colt Edin Antique Engine Archives 0 07-06-2001 12:24:17 AM
