Want To Glew Rubber To Metal
this thread has 7 replies and has been viewed 1217 times
Old 08-18-2005, 10:00:34 PM
Sonny Sonny is offline
Default Want To Glew Rubber To Metal
Hi And Thanks I Am Looking For Some Kind Of Glew To Glew Rubber To Steel Wheels On My Centuar G I Thought I Would Glew Than Bolt The Rubber To My Wheels Thanks For Any And All Advice The Wheels Are 4 In Wide About 7 Ft Rd Thanks Sonny
Old 08-18-2005, 10:05:22 PM
Default Re: Want To Glew Rubber To Metal
Sonny]Hi And Thanks I Am Looking For Some Kind Of Glew To Glew Rubber To Steel Wheels On My Centuar G I Thought I Would Glew Than Bolt The Rubber To My Wheels Thanks For Any And All Advice The Wheels Are 4 In Wide About 7 Ft Rd Thanks Sonny
Old 08-18-2005, 10:15:27 PM
Email NOT Working
Sonny, PL400 construction adhesive comes in a caulking tube and will glue 2X4 walls to concrete. It's amazing stuff. I don't know if it would fit the bill for you or not. I've used a prybar, sledgehammer, and all my strength to move walls that were glued down in the wrong spot. I honestly thought the concrete would break before the thing came loose. You could try it on one lug and see how it goes. Ace is the place to get it.
Kevin
Old 08-19-2005, 09:13:54 AM
Jim Tremble Jim Tremble is online now
Hey Sonny
Use Contact Cement. Used for gluing laminates to counter tops in cabnet building. You can get it at any lumber supply or hardware store.
Make sure the surfaces are clean. Follow the directions on the can.
I have used this on many rubber covered steel wheels and have had great success. Easy to apply and no mess. Drying time is important.
Jim
Old 08-19-2005, 09:31:46 AM
Fred_M
RTV Silicon also works great for gluing metal to rubber. Use the clear sealer/ adhesive type in caulking tubes applied to clean dry surfaces allowing 24 hours for it to set.
Old 08-19-2005, 10:34:45 AM
Elden DuRand's Avatar
Images: 6
Originally Posted by Jim Tremble
Hey Sonny
Use Contact Cement. Used for gluing laminates to counter tops in cabnet building. You can get it at any lumber supply or hardware store.Jim
Jim:
I agree that contact cement will do the job. As you say, anyone using this for the first time should be sure to read the instructions because allowing both surfaces to dry before laying them together is counter-intuitive.
Also, you only get one chance when laying the parts together. That stuff REALLY STICKS! If you get something mis-aligned, you might have to start all over and could ruin the parts getting them to separate.
Take care - Elden
http://home.cybertron.com/~edurand
Last edited by Elden DuRand; 08-19-2005 at 10:36:14 AM. Reason: The usual thumb-fingerdness
Old 08-19-2005, 10:45:05 AM
Originally Posted by Elden DuRand
Jim:
Take care - Elden
Eldon,
To release the adhesive, you can use a HOT AIR GUN. As on the wheel and rubber, get a corner lifted and direct the hot air between the wheel and the rubber. Keep tension on the rubber and it will peel back as the cement releases.
Been There, Done That.
Jim
Old 08-19-2005, 11:00:58 AM
Images: 6
Eldon,
Jim
Jim:
That's a nice fact to know! Saves a lot of cussin'.
Take care - Elden
rubber O rings Edwin Scale Model Engineering 2 12-11-2006 09:01:36 PM
RUBBER TO STEEL WHEELS SONNY L Antique Engine Archives 8 08-25-2003 06:11:55 PM
Rubber Rod Bearing? Hal Davis Antique Engine Archives 4 07-12-2002 12:44:12 PM
Rubber checks Ed & Hit & Miss Enterprises Antique Engine Archives 13 06-26-2002 12:42:58 AM
rubber belting Roland Antique Engine Archives 1 07-16-2001 09:53:10 AM
