Small low tension coils
Could someone direct me to a supplier/builder of small low tension coils to use with a 1-1/2 inch...
this thread has 9 replies and has been viewed 1250 times
Old 08-19-2005, 11:26 PM
Paul J. LeBoeuf Paul J. LeBoeuf is offline
Question Small low tension coils
Could someone direct me to a supplier/builder of small low tension coils to use with a 1-1/2 inch bor by 2 inch stroke hit and miss model engine with make & break ignition?
Old 08-22-2005, 10:02 PM
Tim Litzenberger Tim Litzenberger is offline
Default Re: Small low tension coils
Hi, This is my first attempt at answering anyone on this site. Please bear with me for any problems. I am sure I could build a low tension coil for you. I have built severall for my full size hit and miss engines. I have sereral gages of wire to use to build you one. What is the finished size you are looking for? Also what kind of wood finish would like on it? Tim
Old 08-23-2005, 03:14 PM
Forrest A's Avatar
Get a model T buz box, found in most flea markets cheap.
Old 08-23-2005, 05:06 PM
John Newman, Jr.'s Avatar
While a Model T buzz box will certainly work, it is going to appear vastly out of proportion to a model engine - It would be like having a 6' high shipping crate next to a full size engine.
I am facing a similar problem - I am working on making a little engine using my Economy 1-3/4 hp as a guide. Not a copy, but scaling the working components to fit my model. I will be using a battery & coil rather than attempt to build a scale Wico EK mag, that's for sure! I am looking for a high tesnion coil that will be considerably smaller than a standard automotive coil - which would be like having a 40 gal water heater painted black standing next to my full size engine. A little casual research shows that old time model airplane engines with spark ignition used something that would probably be close, but I haven't been able to find one. Anybody got one of these?
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 08-23-2005, 08:49 PM
Hi Tim , I'm told that the small low tension coil I would have to use would be in the 3-4 ohms resistance to operate on a 6 volt , 4.5 amp battery.
Let me know what you can do .
Paul LeBoeuf
Belle Chasse, Louisiana
Old 08-23-2005, 08:55 PM
Hi John, I have a couple of small coils purchased from Cole's Power Models in Calif. They measure about 1 inch dia. by 1-1/2 inch long. This might be what you want. I don't have info on the resistance factor etc.
Paul LeBoeuf
Old 08-24-2005, 06:49 PM
Forrest A's Avatar
You could make one yourself. Get a copy of Bob Shores book on model engine coils.
Forrest A
Old 08-24-2005, 09:38 PM
Forrest A
I read Bob Shores book on coil making ,sounds complicated to me with having to make a coil winder first and I'm not very good at electric circuits and such things as ohms etc.
Old 08-25-2005, 02:43 PM
Forrest A's Avatar
You don't have to make a winder. if you are patient and have the time you could wind one by hand. Low tension coils arn't as fussy about the quality of the wind as are the high tension ones.
Forrest A
Old 09-17-2005, 07:51 PM
D. Anderson D. Anderson is offline
I have found that for low tension ignition(ignitor), if you use the secondary winding on a say, 120volts primary to 12 volts secondary power transformer should do the trick. Now, that is, if you don't mind hiding it. Just another option to consider.
Don
Low Tension Coils Charlie Bryant Antique Gas Engine Discussion 3 01-31-2007 08:36 AM
Low Tension Coils ? dannyinky Antique Engine Archives 19 04-20-2004 08:35 PM
Re:Low tension coils DICK GRAYBILL Antique Engine Archives 0 04-19-2004 11:29 PM
low tension coils DICK GRAYBILL Antique Engine Archives 0 04-19-2004 11:22 PM
low tension coils Ron McMorris Antique Engine Archives 4 12-09-2003 10:55 PM
