What is this thang, v-belt question
this thread has 2 replies and has been viewed 1104 times
Old 08-21-2005, 04:08:11 PM
Clifton Clowers Clifton Clowers is offline
Photo What is this thang, v-belt question
I bought this thing yesterday at the Tiffin flea market thinking it was some sort of belt tightener. After starting to derust and lube it up, I can't for the life of me see how it's suppose to work.
The outer sheves are held to a bronse bearing with 3 set screws each and the inner sheves are greased and moveable both around and left and right(the thickness of the belts). The bronze bearing is loose to the inner sheve but is tight to the main shaft.The shaft is held by a set screw and is not suppose to turn,I think. Right now the outer sheves are held tight by the fact that the bronze bearing is stuck fas to the shaft,
I went back today and the guy I bought it from had no idea what it is either.
Thanks for the info guys, I knew you could help. Clifton
Old 08-21-2005, 06:24:54 PM
John Newman, Jr.'s Avatar
Default Re: What is this thang, v-belt question
Looks like a variable speed drive. This device would go between a motor or engine and the pulley on whatever you are trying to power - for identification I will just refer to it as the Machine. You have a v-belt going from the motor to this device, and another belt from this device to the Machine. As you move the lever back & forth it will force one belt down deeper in its groove and at the same time the other belt will climb higher in its groove - thereby changing the relative ratio.
Don't ask me what it might have come out of - haven't a clue.....
John Newman, Jr.
Saint Louis, MO
Old 08-21-2005, 10:00:12 PM
Thumbs up Re: What is this thang, v-belt question
Definatly a variable speed drive unit. Nice find!
Belt pulley question Alek77 Farm + Industrial Antiques and Collectibles 3 12-17-2007 09:28:58 AM
Flat Belt question John Newman, Jr. Antique Gas Engine Discussion 6 07-18-2007 08:41:49 PM
MF 40 industrial fan belt question gbritnell Antique Farm Tractors 5 07-18-2007 11:53:41 AM
Flat Belt Question Larry Dunlap Antique Gas Engine Discussion 2 12-06-2005 07:22:43 PM
Round belt question Benny Mckheean Antique Gas Engine Discussion 5 08-26-2005 02:22:41 PM
