Round belt question
this thread has 5 replies and has been viewed 1859 times
Old 08-24-2005, 05:03:02 PM
Benny Mckheean Benny Mckheean is offline
Default Round belt question
I just purchased some 1/4 inch round belting from H&M to run the fan on my Busy Boy engine and would like to know how to join the ends.I have two clips that I ordered with the belt and the only way I see to join them is to overlap them to the desired length and crimp them.Is this correct? Thanks
Old 08-24-2005, 05:23:33 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Images: 72
Exclamation Re: Round belt question
Not sure what your clips look like. But what they use to do is use a Hog ring to join the ends together. Its an oval wire ring split open on one side and the ends are to a point. They had special pliers called Hog ring pliers( go figure) that pinched the ring throught the leather belt and closed the ends close together. Hope this helps.
I Get My Corn From A Jar
Old 08-24-2005, 05:45:12 PM
Frank Y's Avatar
Frank Y Frank Y is offline
Images: 8
Default Re: Round belt question
Yep, its just a butt joint. Put the belt around where you want to go and overlap the ends side by side at the tension you want and cut through both pieces. I drilled a hole with a small bit and slipped the clip through. then just squeezed the clip together with a regular pliers.
Frank Y
Old 08-24-2005, 05:58:00 PM
Junkologist's Avatar
Images: 129
Benny,
What I was told to do is cut your belt to the correct length with the ends butted together. Maybe even a little short, because there will be a little gap when the ends are hooked together. Then, take each end and drill a hole through the belt vertically. Put the hook through the hole in each end from the bottom of the belt and you're all set. It is very important to drill your holes vertically square to the surface and in the center of the belt. Make sure there is no twist in it either. If you are careless, the ends will end up offset and the belt will want to walk out of the groove when the splice enters it.
Mike
Old 08-26-2005, 08:42:14 AM
Phillip Hutchinson Phillip Hutchinson is offline
G'Day Benny.
I used to use a similar belt in a citrus packing shed,it was called "REDTHANE BELTING".It is made from an elastic type of plastic stuff,I cant tell from the pic if its the same but here is how to join it if it is.Get a stainless steel knife clamp it in the vice, heat it with a gas flame but don't burn it place the 2 ends on opposite sides of the knife till it melts then slide it off pressing the ends together at same time.As i said thats if its the same type of belt,I used to use it to drive sizing rollers on a citrus plant,its good stuff.
Happy cranking Phillip
Old 08-26-2005, 02:22:41 PM
Thanks all for the replies.I now have the belt installed with all the good advice I received.
Belt pulley question Alek77 Farm + Industrial Antiques and Collectibles 3 12-17-2007 09:28:58 AM
Question about making a square hole from a round one Farmall Antique Gas Engine Discussion 14 11-14-2007 02:01:06 AM
MF 40 industrial fan belt question gbritnell Antique Farm Tractors 5 07-18-2007 11:53:41 AM
What is this thang, v-belt question Clifton Clowers Antique Gas Engine Discussion 2 08-21-2005 10:00:12 PM
Best way to crimp round leather belt RIRR Farm + Industrial Antiques and Collectibles 2 05-15-2005 08:09:35 AM
