Our Portland find (PICTURE!)
this thread has 17 replies and has been viewed 2233 times
Old 08-28-2005, 11:32:58 PM
Sky
Thumbs up Our Portland find (PICTURE!)
Found another flywheel engine! 2 and half horse jaeger, 550 R.P.M.
Hit & Miss. what a beuty. now i know what some of ya'll ment buy this being addicting!! and i thought i had it down pat!
need a EK mag though. a GOOD one. anybody wanna sell me one?
i need to find the year of this thing, will post numbers tomorrow.
Not me in the pic, that me dad.
Old 08-29-2005, 06:26:32 AM
Neale Behm Neale Behm is offline
Images: 2
Default Re: Our Portland find (PICTURE!)
Skylar,
You're gonna need this website. You'll find just about anything you want to know about your new Hercules there
http://www.herculesengines.com/hercules/index.htm
Good luck and keep us posted!
Thanks Harry
Old 08-29-2005, 11:17:28 AM
Sky
Thanks for the info! i'll have to look at the engine numbers and see what year it is, this will be intresting..
Old 08-29-2005, 03:02:11 PM
Rex Pyles Rex Pyles is offline
Images: 7
I know for sure it needs to be put in time skylar.
Old 08-29-2005, 06:50:57 PM
Sky
What do you mean rex?
the engine looks timed to me
Old 08-29-2005, 06:55:36 PM
Sky
Originally Posted by Neale Behm
Skylar,
Thanks Harry
cant find my engine year neale, my serial numbers are in the 30,000 range
Old 08-29-2005, 07:55:58 PM
Images: 7
I sold it to tom winland.....
Old 08-29-2005, 09:27:04 PM
Sky
so i just time the timing marks, right?
Old 08-29-2005, 09:44:00 PM
Images: 7
that would be a good place to start
Old 08-29-2005, 09:44:51 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
so what your saying Rex is that you sold me a engine that was out of time huh, you told me it ran.
Old 08-29-2005, 10:02:24 PM
Gasengn Gasengn is offline
2 1/2 HP and three hole flywheels. It has to be 1928 or 1929. The serial number would be in the 355,000 to 375,000 range. There may be a casting date on the head and/or block.
Glenn
Old 08-29-2005, 10:09:28 PM
Sky
K.......so now i have to time it.....what do the timing marks look like on this so i can time it?
Old 08-29-2005, 10:46:22 PM
Ray Cardoza's Avatar
Purddy little thing. I'll be getting my "new"toy soon
Old 08-29-2005, 11:10:57 PM
Sky
still need to know what the timing marks look like but i just now went outside to look at the engine numbers and this is what i find, perhaps this might tell the year? Size No. 3-1/2 L
Serial No. 34585
Engine No. 289126
550 R.P.M.
2-1/2 S
whats the L and S stand for aswell?
Old 08-30-2005, 06:39:45 AM
Images: 2
Look for the timing marks on the side of the gears that is next to the block. Once you get the gears cleaned off the marks should be pretty obvious.
When you get around to setting the magneto you'll find it a little frustrating. There will be several adjustments that will tend to effect each other. You just have to keep tweaking each one a little back and forth to get them all where you need them.
Thanks Harry
Old 08-30-2005, 06:46:29 AM
Chuck Martin's Avatar
Chuck Martin Chuck Martin is offline
Images: 17
To time it .....
1. Turn to top dead center on the compression stroke, piston all the way in, with the crank horizontal, mag tripped.
2. The cam gear, (big gear) has a raised tab on it, it should be pointing to the key way slot when the flywheel is rotated slightly.
Take the spark plug wire off. It may not run, but it could still fire.
Once you set that, the mag should trip before the top of the compression stroke. If the crank position at compression stroke is 9:00 oclock, then set the trip to happen at 8:00 oclock.
This will be close enough to get it to run, then you can tweak it..........
Old 08-30-2005, 11:57:28 AM
Mike Monnier's Avatar
Hoarder
If you pull the plug wire, please make sure to ground it properly. You don't want to ruin your freshly rebuilt mag by "open circuiting" it. Good way to toast the coils.
Old 08-30-2005, 09:22:40 PM
Sky
Serial No. 34585
Engine No. 289126
550 R.P.M.
2-1/2 S
Anyone know the year of the engine?
What did you find at Portland? JKWidener Antique Gas Engine Discussion 13 10-21-2007 08:29:30 PM
Portland Stakers Friday picture Fred Van Hook Antique Gas Engine Discussion 10 08-28-2007 11:50:14 PM
trying to find picture of engine shed, Here or GEM Mac Leod Antique Gas Engine Discussion 5 03-08-2007 02:22:17 AM
Portland Picture John Newman, Jr. Antique Gas Engine Discussion 3 05-21-2006 04:39:35 PM
Where is stakers picture from portland? HBurk Antique Gas Engine Discussion 14 08-30-2005 09:52:33 PM
