coilsi have serveral car coils (ford) with & without resistor build in, which one should i use on my 2hp...this thread has 6 replies and has been viewed 943 times
i have serveral car coils (ford) with & without resistor build in, which one should i use on my 2hp united ?
From what I know, the coils with a built in resistor can operate on 12v while the ones that require a separate resistor are 6v (the resistor drops the 12v to 6v). So basically it then depends on what kind of battery you wish to use.
i use a 12 volt small battery 1.8 amps ,would using the 12volt coil with the resistor build in, be ok, with out resistor have weld points before.but boy does that ignitor set a blue spark.
Just connect it in series with the coil and away you go. If you can't get a hot enough spark to start the engine, just short out the bulb 'til she's runnin' then remove the short. Nice thing about this arrangement is that, if your engine quits when you're not there (that's the time most of 'em stop) and it stops with the ignitor points closed (How else!), the bulb will keep you from having to scrape the coil guts off of everything. Take care - Elden |
Take care - Elden Last edited by Elden DuRand; 09-01-2005 at 03:29 PM. Reason: words my up jumbled some - haddta fix. |
| Buzz coils | normaisobel | Generators & Motors General Discussion | 8 | 10-27-2007 10:04 AM |
| coils | Bo Thompson | Antique Gas Engine Discussion | 12 | 01-03-2006 09:54 AM |
| coils | Alex F | Antique Gas Engine Discussion | 0 | 08-08-2005 09:54 PM |
| Coils | Greg Ledger | Antique Engine Archives | 4 | 03-13-2004 11:20 AM |
| EK Coils | Jim Sherman | Antique Engine Archives | 3 | 03-15-2003 09:13 PM |
