Carb info needed
this thread has 2 replies and has been viewed 1155 times
Old 08-31-2005, 07:28:53 PM
Andy Delikat's Avatar
Andy Delikat Andy Delikat is offline
Default Carb info needed
I hope that someone out there can help me with the carb I am working for a friend of mine. The carb looks like a 1 1/4" schebler, but I think that was made by fairmont for there speeder cars, it has Fairmont model J-3A cast where Schebler would be. Anyway to my problem, where the carb mounts to the engine there is valve and seat and I not sure what this valve looks like as there is not enough left to measure. The shaft that the valve slide back and forth on looks like is a hollow, but again there is not enough left to measure. I hope that the pictures will explain what I'm talking about. Any information is greatly appreciated.
Thanks Andy
Old 08-31-2005, 07:57:13 PM
Default Re: Carb info needed
It looks like it is just an intake check valve used on a 2-stroke engine except that it appears to flange mount directly to the "Schebler" body. Ordinarily on a Schebler-type carb, a throttle valve assembly would bolt to the carb body and the check valve, if used, would be screwed into the throttle assembly. There would also be an air inlet assembly that had a compensating valve.
I doubt that rebuilding the check valve would require exacting specifications. You'd need a disc that was exactly flat or that has a soft material attached to allow for seating, a light spring to provide positive closure but easy to suck open, a guide to follow the "stem", and some bolt or cotter pin to keep things from coming off the stem.
What type/make/etc of engine is this carb destined for? How is the carburetion throttled? Are there more parts to the carb that aren't shown??
Hopefully someone with specific knowlege will reply! Perhaps this helps get you started.
Old 08-31-2005, 08:25:43 PM
The carb is off an early Fairmont speeder motor I have all the rest of the parts just didn't picture them. I am not sure what controls the throttle as all I have is the carb that I'm working on for a friend. Thanks
Moline & Twin City Carb Info Needed CharlieBiler Antique Farm Tractors 1 09-17-2006 09:56:16 PM
IH, JTW Carb Help Needed Roger Steckhan Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-02-2006 02:18:00 PM
Carb info needed for a B&S 3-1/2hp engine Karl T Schwab Small Air Cooled Gasoline Engines 2 10-28-2005 11:01:40 PM
Carb ID help needed Randy Hart Antique Engine Archives 1 07-20-2003 12:32:49 PM
Schebler carb help needed Ken Erman Antique Engine Archives 5 08-08-2001 09:43:55 PM
