Kohler Generators
Kohler RV Genset
HELP!!!!!! i just bought a 1996 Cruisemaster MH by Georgie Boy. The Generator was out and in the...
this thread has 4 replies and has been viewed 1672 times
Closed Thread
Old 09-03-2005, 12:00 PM
Kim Paige Kim Paige is offline
Default Kohler RV Genset
HELP!!!!!! i just bought a 1996 Cruisemaster MH by Georgie Boy. The Generator was out and in the coach. I was told by the shop that serviced it that it needs a stator, volt reg, fuse holder, start/stop switch and a ground strap. I want to get a factory service manual, Am I asking too much??? Anyone out there know where I can get one or tell me how to trouble shoot. I do not have the model number with me right now, but I do know it is powered by a Magnum 20 hp (ep) engine and is 5,000 watt. Thanks so much anyone, Kim
Old 09-03-2005, 02:59 PM
Default Re: Kohler RV Genset
Sounds like quite a project. You might send the stator to a motor rewind shop for repair, but it sounds uneconomical even so. Maybe you can find a parts set to purchase. Maybe one with engine problems.
Contact Kohler to see if you can get the things you need.
You have enough engine for more generator capacity if you can find a larger generator end that will fit. Maybe as large as 10-12kW. Of course you can put as large as you want on it, but the engine won't be able to drive anything much bigger than 10-12kW to full capacity. There are some imported generators for sale pretty cheap.
Jim
Old 09-04-2005, 04:55 PM
K D Redd K D Redd is offline
I think the engine is a 20 hp is this genset is a 4 pole/1800 rpm unit and the engines 20 hp rating is at 3600 RPM.
Kent
Old 09-05-2005, 12:04 AM
Bet you're right Kent. I didn't think of that.
Old 09-05-2005, 05:09 PM
Hi Guys, Thanks me again, It is a 5CKM21 model. I tried to get it to run today it fired but did not stay running, I need to rig up a gas tank for it, LOL I'll let you know if I get any output, LOL Kim
Closed Thread
Kohler S-36A genset TSmith Kohler Generators 4 02-03-2008 01:03 PM
My first Kohler Genset Meco3hp Kohler Generators 11 09-17-2006 04:13 PM
Kohler genset help please Rogeralan Kohler Generators 4 06-20-2006 11:17 PM
Kohler 2M1 genset Jim Dunmyer Kohler Generators 4 10-25-2004 07:33 AM
Kohler K7 genset Alan James Kohler Generators 5 03-28-2004 08:12 PM
