| Notices |
Frisco StandardI just picked up this Frisco Standard, it's in pretty good condition but as with all of the marine...this thread has 5 replies and has been viewed 1259 times
I just picked up this Frisco Standard, it's in pretty good condition but as with all of the marine engines from this part of the country its been run in salt water. Is there any way of nuetralizing the salt in the water jacket?
Thanks, Jim
"When guns are outlawed, only outlaws will have guns" Jim Sherman
Don't know of any way to neutralize your salt other than to just flush it with lots of clear water.
Very impressive motor you got there! Is there some kind of heat exchanger in the cylinder jacket to pre-heat the air for the carb? The pipe that goes from the bottom of the jacket to the inlet side of the carb is why I ask. |
[quote=
Very impressive motor you got there! Is there some kind of heat exchanger in the cylinder jacket to pre-heat the air for the carb? The pipe that goes from the bottom of the jacket to the inlet side of the carb is why I ask.[/QUOTE] John The air intake is on the other side of the engine. It is a screen-grate affair. The air passes around the hot cylinder and and enters the carb via the tube that mentioned. Jim |
John,
It appears that warm air is drawn in from around the lower portion of the cylinder, notice the vent holes on the opposite side. It is one heavy engine for a 5hp.
Jim
The best way to preserve your salt water exposed engine is to keep the water jacket full of antifreeze when not in use. When the jackets get dry the salt crystalizes and swells, breaking the cast iron apart ! Great old marine engine ! |
| Frisco standard | JeffSurber | Antique Marine Engines | 5 | 01-12-2008 01:29 PM |
| Frisco Standard Video | Jim Sherman | Antique Marine Engines | 3 | 05-09-2006 09:10 PM |
| Frisco Standard video | Jim Sherman | Antique Gas Engine Discussion | 3 | 10-11-2005 11:25 PM |
| Frisco Standard s/n list? | Jim Sherman | Antique Gas Engine Discussion | 0 | 09-06-2005 02:23 PM |
| Frisco Standard | Jim Sherman | Antique Gas Engine Discussion | 0 | 08-20-2005 09:31 PM |
