Go Back   SmokStak > SmokStak® Support and Information > How to use this web site:
Dial-up users: speed up screen displays...
Enginads or Smokstak: On the main index page. If there are sections that you've already seen or...
this thread has 0 replies and has been viewed 2794 times
Old 09-11-2005, 06:09 PM
Default Dial-up users: speed up screen displays...
Enginads or Smokstak: On the main index page. If there are sections that you've already seen or don't need, there is an up/down arrow or a +/- over at the right side of the separator bars. Click that and you will expand or shrink that particular section, saving the download time for that section.
Smokstak: go to: UserCP (SETTINGS) > Edit Options > Thread Display Options > and uncheck Show Images (including attached images and images in [IMG] code.) Doing so will cause all attachments to be represented as clickable links rather than images. The only time you will wait for a photo to show is when you click one. You can also unclick "Show Avatars" and "Show Signatures" at the thread display options section of your control panel.
-- Harry
Thank you for being a Subscriber!
Dial up answering services Cody C Computer, Camera and ISP Problems 0 03-12-2008 06:16 PM
More Oblong Displays Fred Van Hook Oil Field Engines 1 12-22-2006 08:34 PM
Wrench Displays at shows Frank Y Antique Gas Engine Discussion 8 12-05-2005 11:08 AM
Aermotor displays Farmall Antique Gas Engine Discussion 6 09-05-2005 11:39 AM
Driveway displays Kevin Beitz Antique Engine Archives 14 12-13-2002 09:12 PM
