Welding Shop
Old Hobart Welder
Hi can any body ID this machine? If so How do I hook it up and make it work? I have seen a similar...
this thread has 7 replies and has been viewed 6246 times
Old 09-11-2005, 07:51 PM
DaveHath DaveHath is offline
Photo Old Hobart Welder
Hi can any body ID this machine? If so How do I hook it up and make it work? I have seen a similar one running off a stationary engine. I'm kinda new to this old equipment. Here is what I know about it. HOBART MML-304 ARC WELDER, WHEELED, GENERATOR 300AMP-40V, MOTOR-220/ 440V, 3PH, 20HP, 1750 RPM, 52/ 26 AMP. Can this be made to work off a stationarey engine and be skid mounted?
Old 09-12-2005, 12:18 PM
Photo Re: Old Hobart Welder
Sorry I forgot the pics,
ID:	3747   Click image for larger version
Old 09-15-2005, 01:27 AM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
Images: 16
Default Re: Old Hobart Welder
Dave,
That "thing" is a "dynomotor" ! It uses the 222/440 to turn the armature which has 2 sets of windings and 2 commutators...1 winding is for running and the 2nd winding generates the 40volt,300 amp welding current.
Since it has a covered bearing on each end there would be no practical way to install the pulley that would be needed to run it with an internal combustion engine! UNLESS a way could be devised to direct couple it inline with the driving engine shaft. Then direction of rotation might be a problem !
Even if you were successful in hooking it to an engine and if the driving windings can be rewired you would still have to figure out a control system and it would still generate 220/440/40 which would be usless for house hold use.. It would be a conversation piece but it'll still just be a welder!It's just not practicle !
My opinion,for what it's worth, is to put that in Harrys Classified's, there's got to be someone out there that could use a welder like that! It must have a "bodacious" duty cycle !
And then look for a dedicated generator,either operational or not ! The help on this site is phenominal( think I spelled that right) ,so help to get it going is just a few keystrokes away !
Gene
Old 09-16-2005, 09:16 PM
Thanks, I'm not really interested in using as a generator. I need to set up a good mobile DC stick welder to mount on a trailer for maintenance work. I'll probably sell it and replace it with Gas or Diesel powered unit.
Thanks Again
Dave
Old 01-03-2006, 10:36 AM
Carl Wheeler Carl Wheeler is offline
My grandfather had one just like it in the shop. It has to have 220/240V to make it run. Carl
Old 01-04-2006, 10:11 AM
K D Redd K D Redd is offline
Could be used in a shop which has a 20 HP RPC ( rotary Phase Converter)
Kent
Old 01-10-2006, 09:14 AM
Robert Ward Robert Ward is offline
To DaveHath,
What did you decide to do with the old welder? Do you still have it? I have 480, 3 phase in my shop, so I could run such a unit with no problem. Do you want to sell it?
Old 01-10-2006, 09:17 AM
PS to DaveHath,
My email is as follows:
robert.j.ward@usace.army.mil
Bob
wiring for hobart welder 440 to 220 Don Aldrich Welding Shop 1 07-02-2007 10:40 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 02:54 PM
Hobart Welder/Generator Martin Dollar Welding Shop 2 12-23-2006 02:47 PM
Hobart welder parts. John Bailey Welding Shop 2 12-14-2005 10:31 PM
DCC-353-P Hobart Welder Rob-n-LA Welding Shop 2 07-17-2004 04:55 PM
