Detroit Engine WorksThis is my Detroit 3hp Stationary engine, One of the first fuel injection engines ever manufactured...this thread has 2 replies and has been viewed 1551 times
This is my Detroit 3hp Stationary engine, One of the first fuel injection engines ever manufactured sometime between 1907-1916.
http://www.antiquengines.com |
What does it say on top of the injecter pump? (on the round lid) Yours has the earlt 2 piece injecter, What is writtrn on the injecter body can pin the age down even better. The engine is definatell pre 1914, that is when the 1 piece injecter appears. The 2 piece injecter appears as an option on the Detriot Engine Works Marine engines as early as 1904!
Andrew The S/N for the engine should be stamped into the crankshaft, under the brass cap, on the timer side of the engine. Andrew
Hello Andrew,
The two piece Automatic fuel feeder-injector (patent # 926,892) was designed by John Peterson and Frederick O. Peterson patented on July 6, 1909 manufactured by Ben J. MiddleDitch for Detroit Engine Works 1909 through 1916. Sources = (U.S. Patent # 926,892), (1909 Engine Catalog), (Bulletin No III Jan 1st 1912), (Bulletin No III part 3 Nov 1st 1914), (1915 Engine Catalog), (Information embossed on Peterson fuel feeders). The one piece fuel feeder-Injector (patent # 1,026,425) was designed by Frederick Barthel and patented May 14, 1912 manufactured by Detroit Engine Works 1912 through 1916. There were 3 styles of this one piece fuel feeder/Injector produced. 1st style had a flat top with hex nut on it. 2nd style had a flat top with a u shaped tube on the top. 3rd style had a Acorn hex nut top. Sources = (U.S,Patent # 1,026,425), (Bulletin No III Jan 1st 1912), (Bulletin No III part 3 Nov 1st 1914), (1915 Engine Catalog). I have copys of the patents on my website along with a lot of other literature and photos you might find interesting. http://www.antiquengines.com John Davis |
| Nelson Brothers, Detroit Engine Co., Detroit Engine Works. | John Davis | Antique Gas Engine Discussion | 3 | 04-01-2008 07:59 PM |
| Detroit Engine Works | John Davis | Antique Gas Engine Discussion | 7 | 11-21-2005 01:25 AM |
| Detroit engine works | Andrew Mackey | Antique Engine Archives | 1 | 04-12-2004 02:05 AM |
| Detroit Engine Works | mike inglis | Antique Engine Archives | 4 | 02-08-2004 10:56 PM |
| Detroit Engine Works | John Davis | Antique Engine Archives | 1 | 08-30-1999 02:33 PM |
