Winch mounts
There have been several good posts recently about winch suggestions. I'd like to get some ideas now...
this thread has 3 replies and has been viewed 1381 times
Old 09-21-2005, 11:10 AM
JCullom's Avatar
JCullom JCullom is offline
Default Winch mounts
There have been several good posts recently about winch suggestions. I'd like to get some ideas now on how you all have them mounted. I'd like to put mine on a mount at the front of my trailer where it can be removed easily, but is still very strong. If you can, take some pics of yours.
Old 09-22-2005, 04:17 PM
Brian D. Brian D. is offline
Default Re: Winch mounts
Here are some pics of how I mounted my winch. I used channel iron that matched the same size as the base of the winch. I need 12" approx. to clear the front rail of the trailer so I used some 12" channel and coped it to fit the top piece. when I had finished the final fit up on the trailer, I tacked it all together and removed it to weld. I used 6, 3/8" bolts to mount the ass'y. The winch came with 4 bolts to mount it so I figured that would be more than strong enough. I tested it for the first time this morning by loading my Case L and it did'nt flex one bit. Brian D.
Name:	IMG_0577 (Small).JPG
ID:	3890   Click image for larger version
Name:	IMG_0578 (Small).JPG
ID:	3891   Click image for larger version
Name:	IMG_0579 (Small).JPG
Old 09-24-2005, 09:39 PM
JCullom's Avatar
Thanks Brian, that's just what I'm looking for. Why didn't you weld the assembly to the tongue, instead of bolting it?
Old 09-25-2005, 12:17 AM
I wanted the whole ass'y to be removable. My father uses the trailer for construction and has a large gang box that he mounts on the front and the winch would interfere with it. I took my Case L to a local threshing day this morning and ended up loading and unloading the tractor three times and it worked with no problems. If you end up using this type of mount, let me know if I can help with any more pics or info. Brian.
Winch advice Frank Y Trucks, Trailers and Hauling for Shows 24 11-02-2006 12:27 PM
Need advice on a winch Chris Kirk Trucks, Trailers and Hauling for Shows 11 10-16-2004 09:16 PM
Winch of interest Arnold Stationary Steam & Traction Engines 0 07-15-2004 08:46 PM
Winch or Slave(s)?? Jeff Holbrook Antique Engine Archives 10 05-13-2004 10:08 PM
the best trailer winch to buy Aaron Abey Trucks, Trailers and Hauling for Shows 16 05-08-2004 10:52 PM
