Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
4 Cylinder Atlas Imperial
Here is a big old ugly Atlas Imperial that dad came across the other day. I always loved these...
this thread has 15 replies and has been viewed 6008 times
Old 09-28-2005, 02:25 AM
Tanner Remillard's Avatar
Images: 10
Default 4 Cylinder Atlas Imperial
Here is a big old ugly Atlas Imperial that dad came across the other day. I always loved these engines.
Old 09-28-2005, 07:30 PM
Jordan's Avatar
Jordan Jordan is offline
Default Re: 4 Cylinder Atlas Imperial
Holy cow sure is big.
Old 09-28-2005, 09:53 PM
John Newman, Jr.'s Avatar
Pardon my ignorance, but it looks like it has 3 push rods / rocker arms per cylinder. Which has 2 valves - intake or exhaust?
Show us that engine again when it starts coming together.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 09-28-2005, 10:08 PM
Andrew Yeary's Avatar
Andrew Yeary Andrew Yeary is offline
Tanner can't wait to see that engine when its done in ten years
Andrew Yeary
Old 09-28-2005, 10:23 PM
Images: 10
This engine IS'NT mine unfortunately, just thought I would post a pic of it. And the old guy that ownes it would rather see it rot into the ground then do anything with it I guess
Old 09-28-2005, 10:26 PM
well Tanner, I gave you ten years to get it done. That should be plenty of time to talk him out of it and restore it. Your going to be busy if all these old timers give in to you and sell (hopefully cheap) You'll have prijects for the next 100 years. I'm sure we won't here you complaining.
Andrew Yeary
Old 07-12-2006, 11:51 PM
Brad Kelley Brad Kelley is offline
Images: 47
Here's what it could look like, with a little TLC. This engine runs at the Tuckahoe engine show in Easton, Maryland.
cheers
Old 07-13-2006, 08:37 AM
Atlas Imperial was an early user of a common rail fuel system. The center push rod will work the fuel injector. I toured Death Valley this spring. There was an Atlas there in about the same condition
Old 07-13-2006, 10:57 AM
There are various Atlas engines operating in and around the Pacific Northwest and some talented repair and maintenance is available for those in need.
If you were lucky enough to attend the Wooden Boat Festival Fourth of July weekend at the Center for Wooden Boats in Seattle, you likely saw the "Agnes Foss", a towboat built 1902 and presently powered with a wonderful Atlas that runs like a top.
The owner. a top of the line vintage diesel specialist, allowed full access to the vessel and displayed a photographic history of the boat and her machinery for 4 days as young and old visitors came and went.
Believe me when I say that a workboat with an Atlas would be a joy to work on as they go ka-chunk, ka-chunk, ka-chunk all day and all night long.
Not enough power for commercial boat owner's, though, and who cared if the crew all go deaf, we got work to do !!!!!!
Yeah, if you like looking at an Atlas sitting on blocks, imagine piloting the "Agnes" up the Inside Passage from Seattle to, say Skagway, Alaska where the Klondike Goldrush stampeders disembarked. And then back.
Just a thought or two that popped up reading this thread. I would buy that Atlas if I was you and get the electrolysis vat working overtime !
Old 07-13-2006, 04:48 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
If you are interested take a look at:
http://www.oldengine.org/members/levans/atlas/
to see some pictures of a 3 cylinder Atlas a friend of mine got running earlier this year. If you look at these and the other pictures posted you will notice that there are actually 4 push rods per cylinder: intake and exhaust and fuel injection as mentioned and the 4th. one is for the compressed air starting system.
The attached picture is the one mentioned in Death Valley. You can see more pictures of this engine and other old iron in the area at:
http://www.oldengine.org/members/levans/dv/
Regards,
Larry
Old 10-08-2006, 08:36 PM
oldtool53 oldtool53 is offline
Hi,
I helped to rebuild an Atlas Imperial back in 1976. It was an 8 cylinder turbocharged direct reversing marine unit. Built in 1954. It required 250 psi of air injection for starting and shifting the camshaft. One heck of an air system.
Mark In New Bern NC
Old 10-10-2006, 08:18 PM
In my prior response, I refered several times to the Agnes Foss as a boat with an Atlas but I should have said Lorna Foss.
The Agnes had twin E.M.D. 12- 645's.
Old 10-12-2006, 02:12 AM
Here's some video of a 3 cylinder Atlas at the Hastings, MN, show:
http://www.smokstak.com/forum/showthread.php?t=32823
Old 10-18-2006, 09:44 PM
ChadYelland's Avatar
ChadYelland ChadYelland is offline
question,, the firt engine has 3 push rods wich we wondered about, the others have 4,, but 1 has no spring on the bottom like the rest? so it doesnt seem to be another valve, possilble do do with starting on air or decompression?
. allso i see a tapered key changes the fuel delivery amout, but would it not make the pump late at low load and earlier at high load??
Old 12-28-2006, 03:26 AM
Robt.'s Avatar
Robt. Robt. is offline
Here's another one, and it's for sale it says:
http://www.oldmarineengine.com/discu.../5/100793.html
Old 08-12-2007, 10:47 PM
Boatbum Boatbum is offline
Images: 2
The fuel wedges only change the amount of fuel sprayed into the engine, the injector is mechanically actuated from the camshaft. So the wedges sliding in vary the lift of the injector not the timing. It's a really slick system and works well.
There are springs onall the lifters, there just not all visible as the injector springs because they are down on the block at the base of the lifter. I love my Atlas and the exhaust note running at 100 rpm and watching the prop wash!!
Keith
Atlas Imperial parts still needed! DirtbikePilot Antique Gas Engine Discussion 3 06-21-2009 02:19 PM
Atlas Imperial parts needed!!!! DirtbikePilot Antique Gas Engine Discussion 5 08-15-2007 04:38 AM
Atlas Imperial Engine Dan Donaldson Antique Engine Archives 6 05-20-2004 08:09 AM
Atlas Imperial Diesel(Gas Engine) Alan James Antique Engine Archives 6 01-03-2002 02:48 AM
info needed, atlas-imperial PAUL RANDALL Antique Engine Archives 0 08-14-1999 04:33 AM
