New Holland compression relief
Have a 5 HP New Holland with a compression relief/release (correct nomenclature?) setup below the...
this thread has 7 replies and has been viewed 863 times
Old 10-05-2005, 10:33 PM
Rusty T Rusty T is offline
Default New Holland compression relief
Have a 5 HP New Holland with a compression relief/release (correct nomenclature?) setup below the cylinder. Can someone describe how this works? Maybe even post pictures? My dad's had it for 30 years and we're now trying to start it. I'm using a crank to turn it over and hope I can get the relief/release working before I lose an arm!
Old 10-06-2005, 07:45 AM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Default Re: New Holland compression relief
I would imagine it would be very similiar to the one liked used on my Gal.
Open completely prior to cranking and close asap when you feel it's running fairly good. Waiting too long will cause the valve to carbon up, but that's easlily cleanble.
Does your's have a checkvalve in it?
RickinMt.
Old 10-06-2005, 07:49 AM
Images: 20
http://community.webshots.com/photo/...04083442cnUJgJ
Old 10-06-2005, 12:52 PM
Hey guys, this is a New Holland, an engineering marvel! No simple simple spigot valve would suffice. Somehow it works with a pull chain. I'll post pictures of what I have later.
Old 10-07-2005, 07:26 PM
Corey Robinson Corey Robinson is offline
Right from the instruction book:
1. " For starting the larger engines; pull up on the chain lever to move the exhaust lever away from the engine. This opens the relief valve under the engine cylinder to produce a light compression. The outward movement of the exhaust lever also causes a late spark and prevents kicking back."
2. "On the 2,4 and 5 hp engines the exhaust lever is held aganst the engine frame by a coil spring on the rocker shaft under the cylinder. When this spring is adjuster to tight, the chain lever will not drop on it's own accord after the engine is started and if the spring is to loose the exhaust lever will move away from the basewhile the engine is running, causing the engine not to give full power."
Hope this helps
Corey
Old 10-08-2005, 11:16 PM
Corey, thanks for the post.
This is a picture of the relief valve I have and the side of the engine I believe the chain lever goes on. Sounds/looks like I'm missing the chain lever, exhaust lever, rocker shaft coil spring etc.
Anyone have pics of the complete assembly or know where I could order one?
Old 10-09-2005, 07:33 PM
Hey !
No problems.....as far as what you are missing, I will be going to go see mine this weekend. I will check and can take some pictures of it and snail mail then to you because I don't have the ability to do digital yet!. If you want
e mail me with your address and I can send them!
Corey
Old 10-10-2005, 11:50 AM
e-mail sent. thanks
Making a Compression Relief Valve Mike Antique Gas Engine Discussion 4 08-12-2007 11:19 PM
Wanted: International Famous early Version Compression Relief cast Handle. Uncle Old Iron Antique Gas Engine Discussion 1 05-24-2007 04:54 PM
No relief valve reid? Rich Hudak Oil Field Engines 3 10-30-2006 09:32 PM
Case preheater relief valve setting David Stationary Steam & Traction Engines 1 06-21-2006 07:23 PM
Reid relief valve pressure setting. Myles Lamm Antique Engine Archives 3 10-28-1999 08:33 PM
