Looking for Army TM 5-6115-270-10
I am looking for US Army TM 5-6115-270-10, or a PDF of it. I would be interested in finding any...
this thread has 12 replies and has been viewed 723 times
Old 10-07-2005, 05:08 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Question Looking for Army TM 5-6115-270-10
be interested in finding any place that would sell me a copy or PDF
of the same. Not knowing alot about where these things are to be
found, any information would be "Greatly Appreciated"
Bruce in alaska
Old 10-07-2005, 06:37 PM
ListerDiesel's Avatar
Default Re: Looking for Army TM 5-6115-270-10
Bruce in alaska
What is it for, Bruce? knowing that might make it easier for folks to look it up.
Peter
Old 10-08-2005, 03:49 AM
BTPost's Avatar
Images: 1
Originally Posted by ListerDiesel
What is it for, Bruce? knowing that might make it easier for folks to look it up. Peter
The manual ios an Operations Manual for a 3Kw Wisconsin Powered Kato
Military Generator. Built in 1961 by J.D. Hollingsworth Co. I have the Depot Maintainance Manual but would like a copy of the companion Operations Manual.
Bruce in alaska
Old 10-08-2005, 03:05 PM
Raymond Raymond is offline
Try "roy@milradio.com" They had a manual I looked 2 years for.
Old 10-08-2005, 08:54 PM
BTPost's Avatar
Images: 1
Thanks for the tip and post Raymond. they did list the manual that I
am looking for. I have sent off and email to them to see if they really
have one, in stock, and what the price will be. I appreciate your help.
Bruce in alaska
Old 10-10-2005, 04:46 PM
Bruce in alaska
Here's another one for you to have a look at:
http://www.military-info.com/
Peter
Old 09-12-2009, 12:19 AM
davebrigg davebrigg is offline
armyproperty.com is working on providing a similar manual to the one that I was looking for which will be helpful, also I found a private collection with free pdf downloads with helpful info. but for a newer gen set. I do not have his permission to publish his web address so please use discression:www.igor.chudov.com. The mep017a uses the same voltage regulator as my older unit.
Old 09-12-2009, 07:38 PM
kd5byb kd5byb is offline
Bruce,
Let me know if you can't find one from the above sources. I've got an option that I can try if all else fails.
thanks,
ben
Old 09-12-2009, 07:41 PM
Do you have a title or equipment nomenclature or number like "R-390A/URR"? That would help too.
thanks much,
ben
Old 09-12-2009, 09:59 PM
BTPost's Avatar
Images: 1
Talking Re: Looking for Army TM 5-6115-270-10
Generator Set, Gasoline Engine, 3-Kw, AC 120V, Single-Phase, 120/208V Three-Phase, 120/240V, Single-Phase, 120V 3-Phase, 60-cycle, Skid Mounted
(Hollingsworth Model JHGW3B) FSN 6115-778-6004 April 1961
Winsoncsin Motor Model MAELD L-Head 9.2 HP 3600 Rpm Comp-85-95
Kato Generator Model 3MSW3 Type 9319 3 Kw
That's what I know... from the TM 5-6115-270-20 Organizational Maintenance Manual that I have in Paper and PDF. Still looking for the Operations Manual...
Bruce in alaska
Old 09-13-2009, 09:42 PM
I will check my source tomorrow morning as long as I don't get sidetracked.
thanks,
ben
Old 10-09-2009, 10:21 AM
Bruce - check your e-mail. Took a while, but my source came thru!
thanks,
ben
Old 10-09-2009, 11:31 AM
BTPost's Avatar
Images: 1
I see that trying to come thru now..... Thanks....
Bruce in alaska
Army generator Tom Rowe Generators & Motors General Discussion 5 10-21-2009 09:38 AM
Army lauson? The one banger boy Small Air Cooled Gasoline Engines 24 03-22-2008 12:47 PM
1940s? b&s army gen chrohton Small Air Cooled Gasoline Engines 0 11-04-2006 12:21 PM
army generator parts Russell Daves Generators & Motors General Discussion 1 08-15-2004 08:07 PM
Army Genset Chris B. Generators & Motors General Discussion 1 07-07-2002 10:44 PM
