1935 FM ZC 3 HP Sparkplug
this thread has 11 replies and has been viewed 1265 times
Old 03-12-2001, 11:22:53 PM
Dale
Default 1935 FM ZC 3 HP Sparkplug
Hi, I just got a 3 hp FM Z Style C engine that was made in 1935 from the ser # list.It came with no sparkplug and was wondering if anyone knew the new number(or old # and will cross it with a new number) so i can get a sparkplug from a local suplier.Thanks Dale
Old 03-13-2001, 08:16:44 AM
Ed Kinch
Default Re: 1935 FM ZC 3 HP Sparkplug
If it is a 7/8 thread with a gasket it would be an autolite 3076 or a champion W18.If it has an 18mm thread it is a D14 in champion.
Old 03-13-2001, 10:52:06 PM
Dale
I believe the spark plug hole is a pipe thread type.The 7/8 won't fit i would think.Any more ideas??? Thanks again .Dale
Old 03-13-2001, 11:06:28 PM
Tony Page
1/2" pipe is 7/8" dia. Like some sparkplugs. Tony
Old 03-13-2001, 11:36:47 PM
Ken Majeski
If it's 1/2 pipe thread it would be a champion A-25 or autolite 3095 same as the model T ford.
http://community.webtv.net/KMOilPull/Kensoldenginepage
Old 03-13-2001, 11:37:39 PM
Ken Majeski
Kens old engine page
Old 03-13-2001, 11:42:06 PM
Bill Garman
If it is a pipe thread that you need, try a champion 525 or autolite# 3095. You will find the autolite to be much cheaper, it's what I use in my Cushman engine.
Old 03-14-2001, 12:19:29 AM
Tom
The 3 HP FM Z, style C uses a 7/8 plug. Your local parts house will probably come closest to matching this with a Champion W-18. I've worked on one of these engines several times, and know from experience that the 7/8 plug is correct. The Champion W series plugs are 7/8. You might run up on a W-14, which will fit, but be a colder plug.
Old 03-14-2001, 11:48:22 AM
Scott
I just sold a 1935 ZC that had a half inch pipe thread plug. If you have the head off, take it to your local John Deere dealers parts department, and they'll set you up.
Old 03-14-2001, 11:24:30 PM
Dale
It was a champion 25 and it fits nice.Thanks Everyone Dale
Old 03-14-2001, 11:27:26 PM
Ed Deis
The confusion here is because the earlier 3HP style "C" used a 1/2" pipe thread. I'm not sure what year but possibly the late 3HP C may have used a 7/8" but I believe this change wasn't until the model "52" which is identical except it used a flange mount mag that bolted to c/c cover and the 7/8" plug. The 3HP "C" used a base mount mag with a gear hole cover with a felt for sealing and held on with two screws. Ed
Old 03-16-2001, 12:47:43 AM
Tom
Thanks for clearing this up, Ed. I know that the engine I have worked on in the past, is a 3 HP FM Z, style C. And it does take a 7/8 plug. I've replaced several of them, each time with a Champion W-18, as a local auto parts store happens to stock that particular plug.
The mag is a flange mount, as you have stated.
Extension rims for 1935 wc allis Donald A Smith Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 01-21-2008 07:22:03 PM
1929-1935 Case C/CC Manifold + Kingston Redwing Antique Farm Tractors 2 08-02-2007 09:22:25 PM
timeing a 1935 Allis Chalmers WC Roger Kirschenman Antique Farm Tractors 3 12-22-2005 11:17:18 PM
1935 henry tractor Bernie Niemeyer Antique Farm Tractors 0 06-16-2005 10:21:06 AM
1935 A John Deere Tom S Antique Farm Tractors 1 05-16-2005 12:18:42 AM
