Maytag ID & yearI have an ole Maytag has tag all I can make out is 16 - 26 Stamped at the bottom of tag Runs...this thread has 4 replies and has been viewed 669 times
I have an ole Maytag has tag all I can make out is 16 - 26 Stamped at the bottom of tag Runs complete original Has long Maytag sparkplug dual tip like a split fire model and year ? Bill KY
On the engine flywheel rim there should be a serial number, This number is the only way to date the engine, if it is a model 92 (single, which I suspect it is),or 72 Twin (does not have a tag) By tag, I suspect you are talking about an aluminum plate attached to the engine by the top 2 intake screws. If that is the case, this was an operations data plate, which is available as a repro from sponsers here at the Stak. The model 92 Maytag engine has the unique distinction of being the longest production Internal combustion engine ever built without a major design change. This engine was fitted with 4 different fuel tanks, that affected capacity of the tank, and engine mounting characteristics, but the basic engine was not changed. it was built from 1917 until 1959, with engines built from parts inventory until 1963, when Maytag disposed of all its remaining engine inventory.
Thanks for the info its a model 92 year 1933 not bad for a $ 2.00 yard sale item . had running in 2 - 3 hours work
Only 2 bucks
What a steal Have fun with it!Andrew
The 92 style engine was built from serial number 219612 in September of 1927 to 804444 in early august of 1937. The twin cylinder engines are not actually 72 models. People refer to them as 72s because the model of the Eisemann magneto is 72d and 72 da. Tom |
| Will Maytag 72 power my Maytag washing machine. | triplepass | Maytag Engine Collectibles | 9 | 11-14-2007 12:52 AM |
| Maytag upright year built? | Ihorse | Antique Gas Engine Discussion | 3 | 10-03-2007 02:36 AM |
| What year is it | Ron Willard | Kohler Generators | 2 | 09-12-2006 11:17 PM |
| LB what year! | DaveR | Antique Engine Archives | 2 | 08-01-2003 09:22 PM |
| Maytag Model and Year | Larry Kastens | Antique Engine Archives | 7 | 12-08-2000 12:54 AM |
