Winterizing MCCK
this thread has 2 replies and has been viewed 1402 times
Old 10-24-2005, 11:03:13 PM
Tekfal23 Tekfal23 is offline
Default Winterizing MCCK
I have a 4mcck 1a/1a. I need to winterize it and I see that it has a brass plug on each head. I know those are drain plugs, but is there anything else I need to drain as well?
Old 10-25-2005, 07:52:33 PM
Exclamation Re: Winterizing MCCK
Drain oil, refill and run engine 4 minutes, and turn off fuel supply. Let engine run out of fuel, even choke if possible, to make sure carb is totally MT. Your other alternative is to run engine once a week for 10 minutes, to keep fresh gas in carb, all engine seals lubricated and supple, and dry out the ignition system. (This is better than storing the engine, which in cold climates, will attract moisture thru everything.)
Old 10-26-2005, 02:56:12 PM
Default Re: Winterizing MCCK
So there are no other drain plugs that I need to worry about to get water out of it?
Winterizing engines and such KyleBlankenship Antique Gas Engine Discussion 7 12-02-2007 12:36:10 PM
Winterizing your steamers - what do you do? tirediron Steam Stationary Engines, Traction Engines, Steam Boats 37 10-06-2007 11:42:35 PM
winterizing Mike Antique Engine Archives 17 10-17-2000 04:54:54 PM
Winterizing Richard Antique Engine Archives 0 10-16-2000 07:52:28 PM
Winterizing 2: How do you prevent rust? Norm Antique Engine Archives 1 10-16-2000 07:50:03 AM
