Go Back   SmokStak > SmokStak® General Discussion > Smoke, Flames & Gas (Off Topic)
good (expensive)trick
G'DAY I work for a company that sells and hires forklifts,we where called out to a truck that had...
this thread has 2 replies and has been viewed 787 times
Old 10-27-2005, 09:18 AM
Phillip Hutchinson Phillip Hutchinson is offline
Default good (expensive)trick
G'DAY I work for a company that sells and hires forklifts,we where called out to a truck that had "bit" of a knock,after some questions it was assertained that the owner was washing the truck down with the diesel engine running!,he noticed something on the air intake,you guessed it he washed it with a 1" hose fed by a pressure pump,you cant compress water,it bends conrods instead,true story.
Regards Phillip
Old 10-27-2005, 09:17 PM
BDMelon BDMelon is offline
Images: 11
Default Re: good (expensive)trick
i would say that might put a small curve in some internall parts .oops
i hope the ale he might have been drinking was good . lol
Old 10-27-2005, 11:17 PM
MoRo's Avatar
MoRo MoRo is offline
The gravel screener we use has the air induction coming from underneath. After a rain, water had puddled under there. My co-worker went to start the engine. No bent rods, but she sure smokes now and goes through oil. He change oil and filters 4 times to clear the gray out of the crankcase. Guess overhaul is in order.
~M~
Don't Fall For This Trick Harry Craigs List / eBayŠ Auction Discussion 15 02-08-2007 10:45 AM
Expensive Witte? Jim Sherman Antique Gas Engine Discussion 5 07-10-2006 04:53 PM
Electrolysis did the trick. Fairbanks Kid Antique Gas Engine Discussion 0 08-10-2005 02:32 PM
More expensive aint always better Steve Gerot Antique Engine Archives 9 01-21-2002 10:49 PM
Why so expensive?? Norm Antique Engine Archives 23 04-09-2001 06:03 PM
