Ford Buzz Coil Wiring/ How much resistance
At the swapmeet last week I bought a model t coil and I forgot which post is + - and the...
this thread has 18 replies and has been viewed 2091 times
Old 11-06-2005, 12:10 AM
Ray Cardoza's Avatar
Default Ford Buzz Coil Wiring/ How much resistance
- and the sparkplug. I also would like to know how much resistance it should have. I think it has a bad secondary or primary coil should I also have a condensor in line or does the coil have one built in. Does any one have a wiring diagram they can post for me. Thanks
Old 11-06-2005, 12:49 AM
BobRR BobRR is offline
Default Re: Ford Buzz Coil Wiring/ How much resistance
Ray the top side and bottom posts are for the battery and the lower side post is the plug.It is best to alternate the battery connection helps the points last longer?There is a condenser inside .BobRR
Old 11-06-2005, 12:53 AM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is online now
Go to Harrys home page at bottom click ignitions and buzz coils .Dick.
Old 11-06-2005, 01:15 AM
Like this?
http://albums.photo.epson.com/j/View...041&p=73139492
Old 11-06-2005, 01:18 AM
Thanks guys
Old 11-06-2005, 01:43 AM
Ray first clean the points and all the spots the screws and nuts make contact. I have found that most times that it is a corroded contact that stops these from working.BobRR
Old 11-06-2005, 01:51 AM
Will do. I spent most of this morning cleaning the points up. One side was badly pitted. I'll clean the contact screws tommorow. Thanks for the cleaning tip
Old 11-06-2005, 02:25 PM
Ray make sure and ground the spark so it doesnt try and arc inside.When testing.BobRR
Old 11-06-2005, 03:26 PM
Will do.
Old 11-06-2005, 03:44 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 30
Smile Re: Ford Buzz Coil Wiring/ How much resistance
Ray- The secondary coil should show 3-4k ohms. The primary should show 0.2-4 ohms. The condenser sits on the bottom of the coil opposite the HT leadout. It is about 4" long x 1.2 x .5" If you replace it, make sure it is rated at 0.2-0.4 microfarad at 400-600 working volts. Do not use electrolytic caps as they will fail. A good modern condenser for a lawnmower or older car will work AOK. I have rebuilt ~60 of the darn things over the years. Very important is that the moveable contact have a bit of play- that allows the field to build up before it snaps open. The model T ford club sells an excellent book on the subject of coil rebuilds.
Old 11-06-2005, 03:54 PM
Ok. I'll have to go get a condensor because this one oddly enough doesnt have the condensor in it dont know why but when I poked around in it there wasnt any condsnsor sitting in there.
Old 11-06-2005, 04:19 PM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
Images: 62
Ray,
The condenser is usually separated from coil by a glass insulator. The condeser looks kind of like a folded wad of aluminum foil about 3"long with thin wires connecting it.
Old 11-06-2005, 04:28 PM
Ok. Darn I'll have to get a new one the original is bad. I gues I should have looked closer
Old 11-06-2005, 05:05 PM
BWegher BWegher is offline
Almost all of the original Ford coil condensers have failed by now. Most fail OPEN.
So the simplest fix is to attach a modern condenser on the outside, near the base of the points. One lead to each side, polarity does not matter.
That will fix almost every Ford buzz coil.
Old 11-06-2005, 09:04 PM
Thanks I'll get a new one and see what goes down with it.
Old 11-06-2005, 09:15 PM
Bill Miller Bill Miller is offline
Images: 9
What is the proper way to hook up the condenser on the outside of the
t-coil?
Thanks,Bill
Old 11-07-2005, 11:12 PM
Good question I dont know but I know someone else has to know how it goes.
Old 11-07-2005, 11:49 PM
Dont forget the Archives BobRR
Old 11-07-2005, 11:54 PM
Thanks for reminding me I forgot about those ones
Buzz Coil Wiring for a 2 Cylinder Edwards Engine? Larry K Antique Gas Engine Discussion 15 10-31-2007 12:01 PM
Ford Buzz Coil ssimntih Antique Gas Engine Discussion 4 02-26-2005 12:46 AM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08 AM
Ford Buzz Coil Question Chris Antique Engine Archives 1 04-17-2004 09:41 PM
Wiring with a buzz coil Stan Antique Engine Archives 2 06-21-2001 08:27 PM
