Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines
4HP Oil Well.
Just got a 4HP Vertical Oil Well home, open crank, fan cooled, hot tube ignition, hitNMiss. I...
this thread has 5 replies and has been viewed 1447 times
Old 11-17-2005, 09:55 PM
Greg Shipley Greg Shipley is offline
Question 4HP Oil Well.
I will post a pic tomorrow, anyone know of one around that is complete I can use as a guide?
Thanks.
Old 11-17-2005, 11:08 PM
Brian Lynch's Avatar
Images: 14
Default Re: 4HP Oil Well.
I have a 4 HP OilWell. My engine has a Wico R1 mag, is hit miss and air cooled. I will help you all I can. Is your engine running or in need of repair?
-Brian Lynch
Old 11-18-2005, 11:02 AM
Doug Waggonner's Avatar
Thumbs up Re: 4HP Oil Well.
Yea Greg. I've got one come down here with Tom saturday and check it out! Becides, were gonna need your help loading his engines onto his trailer
Old 11-18-2005, 07:46 PM
Doug, cannot make it to OK this weekend you and Tom are on your own.
I still need to get down your way and check out your stuff though.
The engine is loose, and complete with the exception of oilers and a hot tube orfice.
I will post a pic when after my camera battery charges.
I do have these questions:
1. Should the mains have grease cups or oil cups or a drip oiler on each side,
2. Should the oil tube for the rod and crank journal have a wick on it or does it just drop the oil right on the rod?
Thanks all.
Old 11-19-2005, 07:42 PM
here are a couple pics, I have more, e-mail me and I will send them just running out of space on this server.
ID:	5117   Click image for larger version
Old 11-24-2005, 04:42 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
The mains have oil wells under them. So there should be chains on the crank to pick oil out of the mentioned wells. As to the rod I just let the oil drip into the trough on the con-rod,it works well. They are a very well built engine.
