Need 8 lug axle stubs
I have a homemade tandem axle trailer with mobile home axles with now rotten tires. I want to...
this thread has 3 replies and has been viewed 2063 times
Old 11-19-2005, 09:38 PM
Mark Sergent Mark Sergent is offline
Default Need 8 lug axle stubs
I have a homemade tandem axle trailer with mobile home axles with now rotten tires. I want to convert to 8 bolt hole Ford pattern and have searched for axle stubs and hubs or hubs to run on the present spindles. I have found 8000 lb complete axle to the tune of about $400.00 which dents my engine budget pretty hard. Any help or suggestions would be appreciated.
Old 11-19-2005, 10:28 PM
MoRo's Avatar
MoRo MoRo is offline
Default Re: Need 8 lug axle stubs
4000 lb axle sets at $400 ain't a bad price really, if it's a complete unit with springs.
If you're handy with a welder you might build your own for a few bucks less.
~M~
Old 01-25-2006, 12:53 AM
Les Les is offline
If they are 3" round axles then all you have to change is the hubs. The inner brng should be a 25580 and the outer may be a 14126. The inside dia of the outer brng I believe is 1.5" and a 6k 8 bolt hub should work. The total cost would be about $400 and the hubs should be available from any trailer outlet. Hope it helps.
Old 09-07-2006, 11:51 AM
Fordman Fordman is offline
Northern hydraulics. Got 6 lug hubs for the 1 3/8 by 1 1/4 spindles for $50 each, and there are 8 lug avaliable also.
What Axle Is This ? Roland Finkenbinder Antique Gas Engine Discussion 0 01-30-2005 01:05 PM
Wood axle cart...almost there! Eric McKenna Antique Engine Archives 1 03-21-2004 11:14 PM
Axle done eric M Antique Engine Archives 6 01-21-2004 12:38 AM
final fitting of axle eric M Antique Engine Archives 0 01-19-2004 09:46 PM
Axle length for a 1 1/2hp M? Rob Charles Antique Engine Archives 5 04-30-2003 02:11 PM
