Fairbanks Morse Air compressor???
Hi Guys, I would like to get any information that's out there on this air compressor. The name...
this thread has 2 replies and has been viewed 1133 times
Old 11-25-2005, 07:16 PM
M Newberg M Newberg is offline
Photo Fairbanks Morse Air compressor???
Hi Guys, I would like to get any information that's out there on this air compressor. The name plate says the following: United Pump & Power Co. Manufacturers Perry Pneumatic Water System Fairbanks Morse & Co. Sales Agents Chicago USA. I would like to get an idea of how old it is, and what RPM and pressure it should be run at. EAch piston has a built in relief valve so I imagine that it could have been put on line and it would have maintained what ever pressure they were set at. I also have the old 50 gal. riveted air receiver that came with it. No welds, just rivets and what looks like solder. Are these old air receivers safe to use??
Name:	small photo of air compressor.jpg
Old 11-25-2005, 07:27 PM
Default Re: Fairbanks Morse Air compressor???
Fill your tank with water, pressure it up to twice the pressure you want to run, if it makes it it's safe, if not you may get a little wet.
Old 11-28-2005, 05:29 AM
Phillip Hutchinson Phillip Hutchinson is offline
if its soldered I would be a bit sus using it.We have an old cylinder on our 65 hp National diesel which we pump up to 300 LBS that is riveted and the joint has then been swaged as in boiler practice.Happy pumping Regards Phillip
Parts needed for Fairbanks Morse Compressor JHFoster Antique Gas Engine Discussion 1 05-17-2009 09:40 PM
Fairbanks-Morse Gerry Boose Antique Gas Engine Discussion 1 07-05-2007 12:41 AM
2HP Fairbanks Starting Compressor Lou Quirch Antique Gas Engine Discussion 3 04-17-2007 10:45 AM
fairbanks compressor Derek Pollard Antique Gas Engine Discussion 2 10-11-2006 10:59 PM
Help with Fairbanks, Morse Compressor JHFoster Antique Gas Engine Discussion 0 01-25-2006 05:08 PM
