Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines
15hp Reid Info
I would like to know the bore and stroke of both the cylinders on a 15 hp reid. Also if the cast...
this thread has 4 replies and has been viewed 1665 times
Old 11-28-2005, 08:54 PM
Jim Gorter Jim Gorter is offline
Default 15hp Reid Info
I would like to know the bore and stroke of both the cylinders on a 15 hp reid. Also if the cast iron oilers were used on all parts needing drip oiled or just the power cylinder and the rod bearing. All the restored engines I see have glass /brass oilers on charge cylinder and main bearings. Is this factory installed? Thanks, Jim..
Old 12-06-2005, 05:11 PM
kerogas's Avatar
kerogas kerogas is offline
Stuntman , Pugilist
Images: 11
Default Re: 15hp Reid Info
They use motor oil in every hole . All cast is harder to get busted up by pumpers , kids , and hail ...... the OEM Reid units are thusly made . As to wether they sold their own glass oilers , I will have to defer to a ~real~ guru . But you will find every kind of oiler under the sun screwed into em . Including an optional lolipop oiler set up for the side rod which is a really neat piece of monkey motion .
Some Reid Stuff
http://royalcrossfarm.com/REID.html
Old 12-07-2005, 01:47 PM
Kerogas, Thanks for the info. What is a Lollipop oiler and how do they operate? Were they standard on a Reid? Thx. Jim.
Old 12-16-2005, 08:41 PM
kerogas's Avatar
Stuntman , Pugilist
Images: 11
see here
http://www.smokstak.com/forum/showthread.php?t=26830
the rest of the board
Old 01-11-2006, 12:15 PM
sbeates sbeates is offline
Reid catalogs show both solid brass and brass & glass oilers.
Sue
sleeve for 15hp reid? Jon Powell Antique Gas Engine Discussion 0 01-30-2008 08:23 PM
Another 15hp Reid Project DONE Pix Tom Schoolcraft Antique Engine Archives 0 10-09-2004 01:04 AM
15hp Reid AFretired Antique Engine Archives 2 07-11-2004 10:05 PM
15hp Reid Pix chase Antique Engine Archives 0 01-04-2003 02:00 AM
Re: Weight of 15HP REID Bill Tremel Antique Engine Archives 1 04-05-2000 03:44 PM
