Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft
this thread has 18 replies and has been viewed 29847 times
Old 12-04-2005, 12:23:03 AM
Jordan's Avatar
Jordan Jordan is offline
Question Converting A Vertical Shaft Lawnmower engine to a horizontal shaft
For my first attempt at making a model engine i thought to save on casting costs i would just use a lawnmower engine and make a new base for it and add a couple flywheels. Has this ever been attempted before??
Jordan
Old 12-04-2005, 01:02:14 AM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
Default Re: Converting A Vertical Shaft Lawnmower engine to a horizontal shaft
I Haen't Seen That Done But, I Have Seen Briggs 5s And Briggs Fh Converted To Hit And Miss. I Have Pictures If I Could Figure How To Upload.dick In Central Pa.
Old 12-04-2005, 01:25:29 AM
BWegher BWegher is offline
Sure.
The first rotary mower engines were horizontal PTO converted to vertical PTO
and some were 2-strokes.
Flywheels have a big impact on RPM.
Don't forget that you will have to adjust spark timing. Easier to find an engine that has a mag that can be turned. Most B&S don't have that.
The splash oiling will be messed up. And the carb will have to be turned, etc.
Old 12-04-2005, 01:59:38 AM
John Newman, Jr.'s Avatar
Here is an example of a Briggs FH that has been turned into a Hit & Miss engine. An excellent job, I think.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-04-2005, 10:51:29 AM
If you're going to attempt this conversion I'd stay away from the vertical shaft, too many possible complications. Briggs 5S or 6S should work or possibly a Clinton model 700 or 800. I've seen the Briggs conversion, don't remember seeing a Clinton conversion.
The Briggs FH looks nice because of the external push rod but I hate to see a restorable FH cut up. Besides to me it would be hard to justify chopping up a $250 - 300 engine. But each to his own.
Old 12-04-2005, 06:23:36 PM
Fred Van Hook's Avatar
Images: 480
There is one for sale on Ebay right now. Item #7567414039. I also seen a couple of these engines at Steam Corner about three years ago. They looked like a lot of fun!!
Old 12-05-2005, 07:36:58 PM
George Fair George Fair is offline
Hi Jordan,
Back in June of 2001 “Gas Engine Magazine” was desperate for material and printed a story about a homemade engine that was called “The VBS Engine”. It was made from VOLKSWAGEN parts, BRIGG (& Stratton) parts and SCRAP.
The following site has more pictures of the “VBS Engine”:
http://members.fortunecity.com/nitro.../yougotme.html
Please do not use a collectible engine for your project! If your homemade engine starts easy and runs I’m sure it will attract attention at old engine shows. Spectators are always interested in something different.
George Fair
Old 12-05-2005, 08:49:01 PM
Jordan's Avatar
Hi George,
I have no intentions of using a collectable engine. If I find one that is missing lots of parts i'll use that one instead of a complete one.
Old 12-05-2005, 09:42:38 PM
Chris Euart Chris Euart is offline
About 10 or 12 years ago, I got interested in hit-n-miss engines. Only problem was, I couldn't afford one. So, I took an old 11 HP briggs and "rearranged" it a bit. Now I have a hit-n-miss briggs. I used most all of the briggs parts (crank, cam, piston, governor, connecting rod and cylinder) and a few home-rigged parts. I made a frame out of 3" channel and some 1/4" plate steel, mounted some pillow block bearings for the crank and bolted the cylinder with 4 bolts through the head, cylinder and flat plate. The flywheels came from old textile machinery I bought for 3 cents a pound. And, I almost forgot, it's Chevy powered (points, condenser and coil). It runs great and draws a lot of attention at shows. I had it at Portland this year, anyone remember it? And, by the way, I used a vertical shaft engine. The valve arrangement is perfect for hit-n-miss setup.
Old 12-05-2005, 10:05:34 PM
Sky
wow...thats odd.
doesn't that take some inginuity? i'd like to do something odd like that but i lack the machinery. thus i cant do off the wall stuff...but i sure can try!
but guess im doing some sort of good, i've done alot of things in the past that was said that couldn't be done... hehehe
Old 02-24-2009, 08:11:55 PM
krawlr's Avatar
krawlr krawlr is offline
This place never ceases to amaze and inspire me.
Don Edwards
They call it "smart phone" but "phone" is the dumbest feature on this thing.
Old 02-25-2009, 11:38:09 AM
HoMade HoMade is offline
Let me lay it right out- if you try to take a vertical shaft engine and turn it 90 degrees to be a horizontal shaft, the engine will seize in relatively short order. Most small engines are splash lubricated and the shape of the crankcase and oil dipper are specific to get the oil where it needs to be. A horizontal cannot be used vertically and a vertical cannot be used horizontally. I understand that vertical shaft engines from lawn mowers are cheap to free- but either leave it vertical or find a horizontal shaft. Do not put work, time and money into an engine that will seize from oil starvation.
Old 02-26-2009, 11:50:41 AM
j dayman j dayman is offline
Homade-
Your statement is not true. You can covert vert to horiz engines IF and ONLY IF you make new oil slingers and drill new oil return passages from the valve spring box. If done carefully the engines will last indefinitely. I have several that I converted many years ago. They were all done as 'try and see" projects that lots of people said wouldn't work.
I redesigned the slingers and passages simply by thinking about where the oil pool would be, and arranging the slingers to dip into it and throw some at the bore, the valve spring box, the rod and main bearings, and the cam.
You are correct Homade that if these oiled points are starved of oil the engine will seize and usually go bang.
Don't dip too deep in the oil pool, or you will burn oil, or won't reach max rpm and power.
The carbs and tanks got remounted sideways.
Give it a try on an old or scrap engine Jordan.
Old 02-26-2009, 02:04:18 PM
Forrest A's Avatar
If you use the right engine the gov. gear slings oil in both orientations. My advice if you wish to stand up a lay down but do not want to take it apart just put more oil in so it contacts the end of the crank... I was always one to do what people said couldn't be done and have had a lot of fun doing it.
Old 03-01-2009, 06:11:45 AM
Exclamation Re: Converting A Vertical Shaft Lawnmower engine to a horizontal shaft
In the early 1960s B&S made an effort to reduce inventory by making a 'universal engine'. It was an aluminum block, of about 5 or 6 HP. The block and sump plate was designed so as it could be used as either a vertical or horizontal engine. The fuel tank had a mounting bracket that allowed it to be mounted either on the shroud or the head, the updraft carb needed only a manifold change to be used on either position. The engine had both a rod slinger as well as the rotary slinger for vertical shaft use. I know they exist, I had 2 of them, NOS that were being tossed in a dumpster by an old shop. As I was told by the shop owner, the idea was great in theory, but the demand for these engines did not justify the costs of manufacture. His shop received 10 of the type, and the 2 I got were still there over 30 years later! I still have one in my garage, in the vertical shaft configuration, the other went to a well known collecter of B&S engines here in NJ.
Old 06-15-2009, 12:56:59 PM
Gary Davis Gary Davis is offline
This is one of those Briggs double mount engines. It is mounted vertically currently on an old 60s George tiller. Gary
Old 06-16-2009, 06:18:28 AM
Marc P Marc P is offline
Years and years ago back in Nebraska there were two brothers Harold and ? Barr. They took two aluminum block briggs(?) engines (hor or vert shaft? I don't remember) and attacked them with sawzalls. They made open crankcase hit and miss engines from these old engines, modified the cranks for double flywheels. They had the drip oilers for cyl/piston lube and I don't remember if it was squirt can lube on mains & rod or what. It seems the valves were in a new fabricated head but am drawing a blank. I will ask my brother how much he remembers and if he does will have him add. I will get with my dad to see if he has any pics to scan as well.
I was probably 15 or younger but still remember they were hit and miss.
Thanks for reminding me how old I am.
Old 06-16-2009, 09:32:48 AM
Kevin Pate Kevin Pate is offline
Seen this done before at shows around here. Saw one up in Gray, TN once and asked the guy about it. He used an old "n" Briggs block with a mechanical governor and the head was off of a European scooter with overhead vlaves in it. I think
I have photos of it laying around. Would have to scan them and put them to disk. Keep thinking about doing a project like this one day whe I get the time and my other stuff running properly...
Old 06-16-2009, 03:49:11 PM
Danny J Danny J is offline
I remember those engines M Pavlik (my brother) talked about back in Nebraska. I like him don't remember much except they did fabricate one of the blocks out of plate steel and it used the original governor as a throttle govern, the other was a hit and miss.
Here are a couple of pics of one we have been working on that consists of many FH parts and some plate fabrication for the tank top and crankcase. We are still looking for a proper flywheel and or cooling fan assy.
70s Briggs 5 hp Vertical Shaft Leonard Keifer Small Air Cooled Gasoline Engines 3 06-26-2007 05:55:25 AM
side shaft engine? Mac Leod Antique Engine Archives 16 04-18-2004 02:09:40 PM
VERTICAL SIDE SHAFT Mike Burns Antique Engine Archives 0 10-03-2002 03:42:08 PM
side shaft engine dave Antique Engine Archives 1 06-18-2001 07:14:22 AM
Chicago Flexible Shaft Engine Ed Dina Antique Engine Archives 8 05-26-2000 10:09:56 PM
