Welding Shop
Lincoln SAE 300
I bought a Lincoln 300 amp machine made in the '40s. It has a Hercules JXD motor, that has been...
this thread has 1 replies and has been viewed 2796 times
Old 12-06-2005, 11:23 PM
RandyCldwll
Default Lincoln SAE 300
I bought a Lincoln 300 amp machine made in the '40s. It has a Hercules JXD motor, that has been sitting for a while. I tried to turn it over, and there is not any compression. It looks like the valves are stuck open. I am thinking about selling off the motor, and installing a smaller and more efficient engine. The generator looks to be in really good condition. The brushes are hardly worn. I think there is a market for the engine. If I even parted it out, I think I would be ahead. (I paid 50.00 for the whole thing). Any thoughts?
Thanks Randy
Old 12-07-2005, 02:08 AM
Exclamation Re: Lincoln SAE 300
Unless the engine was submerged, it should be a simple effort to free the stuck valves! Try pulling out the spark plugs, pour in about a cup or 2, of Kerosene in each of the holes. On the side of the engine there should be a couple of steel plates over the valve chambers. Pull the plates, hose the valve stems with WD-40, and gently tap the valves with a plastic hammer, and a screw driver. Between the WD, and the Kero, they should loosen up. Make sure to get most of the Kero out, and change the oil, before attempting to start.
Need help with Lincoln DC-225/3-AS Uncle Willie Welding Shop 1 04-26-2009 08:50 AM
Lincoln SA-200 JackCroisant Welding Shop 4 02-12-2009 03:00 AM
Old Lincoln Ben Bennett Generators & Motors General Discussion 0 09-28-2005 09:09 PM
lincoln help Todd Alexander Generators & Motors General Discussion 1 04-12-2004 11:51 PM
Lincoln Elk Mike Inglis Antique Engine Archives 1 09-10-2002 05:48 PM
