onan ccka
Hi all. Looking for some help in a rebuild that I'm undertaking. It appears to be an onan ccka off...
this thread has 2 replies and has been viewed 2698 times
Old 12-08-2005, 12:06 PM
NayenezGene NayenezGene is offline
Default onan ccka
Hi all. Looking for some help in a rebuild that I'm undertaking. It appears to be an onan ccka off a lincwelder 225, but unsure of the year (74?) or if that even matters. The data tag is gone and The only numbers that I found were on the head stamped in...746748. Anyone that has an operators manual and a repair manual with torque settings, spark plug gap, etc. etc. would appreciate it if I could get a downloadable copy. As well if anyone nows how to tell more info. on the engine (year made and such) would appreciate an answer for that too. Thanks in advance.
Old 12-11-2005, 08:13 PM
Exclamation Re: onan ccka
I will leave this posting here as it is basicly an engine question, but you should try the generater section for answers - in particular ONAN generaters. Quite often generater engines are specific built. Kohler engines are not affiliated with kohler generaters, although most engine parts will interchange! They are 2 seperate entities. The same for ONAN -
Andrew Mackey -Moderater :small engines
Old 01-02-2006, 07:02 PM
Dirk Jr Dirk Jr is offline
Default Re: onan ccka
You can get the CCK, CCKA, CCKB manual from Onan. Or you can surf ebay.
I see them on ebay now and then.
Onan CCKA / Miller welding-generator Jeffl57 Onan Generators 12 02-09-2011 09:10 PM
Onan CCKA Aaron Bouvier Small Air Cooled Gasoline Engines 1 03-04-2010 09:39 AM
Onan CCK vs CCKA djackman Onan Generators 2 11-18-2006 05:29 PM
onan ccka help NayenezGene Onan Generators 8 12-24-2005 03:57 PM
Onan CCKA/miller weld/gen Jeffl57 Onan Generators 2 11-24-2005 09:54 AM
