Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
New to me IHC 3 hp
Just picked up this IHC 3 hp thermoil syphoned engine but I am thinking about putting a pump on it...
this thread has 5 replies and has been viewed 1600 times
Old 12-15-2005, 12:02 PM
Benny Mckheean's Avatar
Benny Mckheean Benny Mckheean is offline
Default New to me IHC 3 hp
Just picked up this IHC 3 hp thermoil syphoned engine but I am thinking about putting a pump on it and using it as a screen cooled,what do you fellows think?
ID:	5565   Click image for larger version
Benny in NC
Old 12-16-2005, 03:57 AM
Default Re: New to me IHC 3 hp
Benny: Thermosyphon is OK, but I like moving parts. Like a piston pump and water flowing over a screen on the tank. It looks better for show. Is it correct, NO , but that's my opinion .
"OLDIHC"-Did you make a new friend today, and a lot .
Old 12-16-2005, 05:47 AM
Thanks Paul.Did the Thermosyphon engines preceed the screen cooled ones?
Benny in NC
Old 12-22-2005, 09:42 AM
Question Re: New to me IHC 3 hp
Paul,Where is the gas tank on this engine?Most IHC's I have seen are in the base but this engine has no holes coming out of the base.
Benny in NC
Old 12-31-2005, 07:03 PM
Card Sponsor
Hi Benny,If there are no holes(would have 3) in the base then the engine was set up as a Victor which had a remote feul tank for use in a building.Parts may have been changed on you engine could be why it has a famous side cover plate.Rob
Old 01-01-2006, 08:53 AM
Thanks a bunch Rob the mystery is coming together now.The adjusting screw on the carb is all messed up and I just ordered a new one from Starbolt.I filled the hole in the carb about 1 1/2 from the end with JB Weld and when it dries I will tap it out to match the original.Does anyone have any suggestions if the JB does not work other than buy a new carb (350.00) wow Thanks all
Benny in NC
