Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Toy Steam Engines and Motors
Help, what is it?
Going through the attic this Christmas season I stumbled upon a piece of machinery under the...
this thread has 6 replies and has been viewed 1271 times
Old 12-22-2005, 12:41 AM
sable86 sable86 is offline
Exclamation Help, what is it?
Going through the attic this Christmas season I stumbled upon a piece of machinery under the insulation. Seems to be a steam engine of some sort. Some say it was a toy steam engine from the 20's. Others say it was part of the machinery used to power and move the old window displays of the time. It has a tag, "Metal Ware Corp, Empire, Model B30". Underneath it has an engraving "PAT JAN 1921". I've already gone to one antique dealer but he was no help. Would anyone here be able to help me figure this one out?
ID:	5676   Click image for larger version
ID:	5677   Click image for larger version
ID:	5678   Click image for larger version
Old 12-22-2005, 12:48 AM
JBoogie's Avatar
JBoogie JBoogie is offline
Images: 127
Default Re: Help, what is it?
i think it is a toy. there is a guy with a website pertaining to these. search google for model steam engines. hope this helps.
Old 12-22-2005, 12:52 AM
I will try that, thank you for the lead...
Old 12-22-2005, 10:05 AM
Alan New's Avatar
Alan New Alan New is offline
It's definitely a toy. I've had several similar to it over the years. There should be a cord to plug into it, as there is a an electric element under the boiler to heat it to make steam to run it.
Old 12-22-2005, 10:24 AM
Elden DuRand's Avatar
Images: 6
I had one of those when I was a kid. I think it came with an erector set. This was in the late '40's so I guess they were around for a while.
Not much of a steam engine, though. I remember that it would barely pull a little erector set ferris wheel.
Nowadays, that's not a problem. It's a collector's item and if it runs at all, that's good enough.
Take care - Elden
Old 12-22-2005, 12:29 PM
Wow! It makes a lot of sense. I did notice a small spindle on it and that would be perfect to wrap some sort of belt or rubber band around.
A little FYI for everyone:
I have just gotten an contact and address at the original manufacturer. I've asked for any history they could provide so I will keep you all posted.
Thank you all for your help!
Old 12-22-2005, 01:22 PM
An eBay search for Empire engine will usually turn up a half a dozen Empire toy steam engines.
