| Notices |
early Gray marineHi I have a Gray marine like Harrys but It has a brass intake manifold with a check valve built in...this thread has 2 replies and has been viewed 1911 times
Hi I have a Gray marine like Harrys but It has a brass intake manifold with a check valve built in also a schebler carb the rear casting has a flat base with 2 bolt holes and a narrow grooved pulley on the crankshaft I think this is for a pump oiler anyone know what make of oiler thank you DEREK
I have a 2 cyl Gray that I am told is a 6hp 1911 . It has a Detroit Lubricator 4 piston oiling system.The pulley that turns the lubricator is broken butwhat is left of it does line up with that pulley on the out drive. hope this helps .I need a fly wheel for mine. If all else fails , maybe I could get the deminsions from one and I,ll have one made.Thanks,Paul
| Gray Marine ??? | cerwin | Antique Marine Engines | 7 | 02-09-2008 08:48 PM |
| Gray Marine (Gray Motor Company) | Derek Pollard | Antique Marine Engines | 7 | 12-18-2007 02:47 PM |
| 6-91 # B?263 Gray Marine Engine | agsem | Antique Marine Engines | 7 | 10-09-2007 01:29 PM |
| Gray Marine | Stevewold | Antique Engine Archives | 1 | 08-21-2004 08:17 PM |
| 62 Gray-Marine | Robert Werner | Antique Engine Archives | 1 | 08-02-1999 07:34 AM |
