Welding Shop
Lincwelder wiring
Hey all! I'm looking for some help to find the wiring schematics for a lincwelder 225 DC. I labeled...
this thread has 12 replies and has been viewed 3291 times
Old 01-11-2006, 10:37 PM
NayenezGene NayenezGene is offline
Default Lincwelder wiring
Hey all! I'm looking for some help to find the wiring schematics for a lincwelder 225 DC. I labeled all of them before I took each one off but as I got this second hand I don't know if it was wired proper to begin with. Any help would be appreciated!
Old 01-12-2006, 01:13 PM
Franzİ Franzİ is offline
Registered 0
Default Re: lincwelder wiring
It should be on Lincoln's web site, www.lincolnelectric.com
You'll need both model & Code numbers
Old 01-12-2006, 08:26 PM
I've not had much luck online with the lincoln website. This welder being from '63 gives out model #, type # and serial # on the main tin plating but it's coded differently than what lincoln uses nowadays for identification. The parts guy even asked me about three times and argued that I wasn't looking in the right spot. But when he called the lincoln guys directly he was surprised that they did have record of it but they had to dig out the microfiche to find it. The parts guy even told me that their service tech may not even touch it being as old as it is, and they in all likelihood don't have a manual on hand anyway. So I figured I might as well learn about this welder myself, seeing as how I'm probably going to be the only one to fix it!
Old 01-13-2006, 12:48 AM
Registered 0
I'll fully agree with you that Lincoln's web site is on the low end of the user friendly scale. It seems to fit in with the rest of their current business plan. If you aren't a major user or a box store peddling their offshore crap, you aren't likely to get a lot of information out of them.
If this isn't your machine, http://content.lincolnelectric.com//...r/im/IM244.pdf
drop back to this page, and go machine by machine till you find yours.
http://www.mylincolnelectric.com/Cat...textsearch.asp
Old 01-13-2006, 07:28 AM
Thanks Franz, I was lucky enough to come across this manual befotre and have it downloaded. Unfortunately it only really covers the exploded view of all main parts components. Although helpful on ensuring a somewhat proper rebuild I'm still scratching my head about the wiring.
Old 01-13-2006, 08:06 PM
ChrisR ChrisR is offline
If you give me your email I have the diagrams your looking for. They are for a 1969 year model but should still be the same as yours.
Old 01-15-2006, 12:09 AM
Thanks Chris. These diagrams will work for me. A little different than what I was expecting but I should be allright with following them. Appreciate the help!
Old 01-15-2006, 04:16 PM
No problem, they came straight from lincoln. Let me know if you need anything else.
Old 03-28-2006, 07:03 AM
benny2000 benny2000 is offline
Hi all. I have just joined this board. I found it while searching for info on my Lincwelder 225.
ChrisR, I am wondering if the info you have covers the Lincwelder 225 with the Lombardini Motori diesel engine model LDA 820? In any case though, I would really appreciate receiving the same info you sent to the other fellow in January. Thanks in advance for your help mate. Email addy is benny1974@hotmail.com
Old 11-05-2006, 02:31 PM
chrisjm chrisjm is offline
Hey Chris , I don't know if ya still have these diagrams , but I have come to have the dame problem...need the wiring diagram for my lincwelder same aga about (60's 70's) I need to know what battery system this uses. 12 volt or 6 volt? Here is my email chriscathym@wmconnect.com Thank You very much.
Old 11-29-2006, 05:53 PM
cMorehead
If you call lincoln elec. at (216-481-8100) service dept. & give them your code# they can e-mail you the diagrams & manuals you need.
Old 01-02-2009, 01:06 PM
Purpleparrc Purpleparrc is offline
Hey i know everyone has bugged you about the diagrams but can you send them to me also. I found the operators mnual but not much help
cparr@cafes.net
Old 01-02-2009, 09:13 PM
K D Redd K D Redd is offline
Default Re: Lincwelder wiring
I went to a local Lincoln dealer when I was working on my OLD THD Wisconsin powered 180 DC. They had a wiring disgrham on file and made me a copy.
Kent
No output on lincwelder 225 DC NayenezGene Welding Shop 1 11-03-2008 11:55 PM
Lincoln Lincwelder 225 ncflatfender Welding Shop 10 03-18-2008 10:51 AM
No power from lincwelder 225 DC NayenezGene Welding Shop 5 11-12-2007 08:28 PM
lincwelder 225dc midnightflyer101 Welding Shop 1 10-14-2006 09:57 AM
lincwelder 225 NayenezGene Welding Shop 4 12-11-2005 01:37 PM
