Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines
Reid 15 hp Water Jacket
Hello to all, How thick is the casting on the waterjacket on a 15 hp Reid and does the jacket...
this thread has 8 replies and has been viewed 1080 times
Old 01-27-2006, 03:46 PM
Jim Gorter Jim Gorter is offline
Default Reid 15 hp Water Jacket
Hello to all, How thick is the casting on the waterjacket on a 15 hp Reid and does the jacket extend over to the crossover chamber and the charge cylinder? What is the best method for cleaning out the scale and mineral deposits in the water jacket?
Second question, on the blowoff valve, is the spring pressure preset at factory or is it adjustable depending on the size and age of engine
Third question, how large of water tank do you need to keep a nonworking 15 hp cool for show purposes and is tank shape critical? Thanks for your help , Jim.
Old 01-27-2006, 06:54 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Sponser
Images: 8
Default Re: Reid 15 hp Water Jacket
Hi Jim,
not sure how thick the casting is but the water jacket does go over the crossover chamber but not the charge cylinder. To clean out the water jackets there are inspection covers that you take off to get into them.
Tom Winland
Ohio
Old 01-28-2006, 05:56 PM
kerogas's Avatar
kerogas kerogas is offline
Stuntman , Pugilist
Images: 11
Its really thick , about 1/2 " or so . Take the clean out covers off the head , and dig around in there with a piece of rebar .
Old 01-28-2006, 06:06 PM
kerogas's Avatar
Stuntman , Pugilist
Images: 11
The pop offs are set at what , 150 PSI maybe ? Some guys run universal ones . A 55 gallon drum will work just fine if its going slow . Shape isnt important ... elevation and the angle of the dangle on the top line -is - if it will be set up for thermosiphon . For an impromtu setup you put hoses on the inlet and the outlet lines , attach a 12V bilge pump to one and then toss it in the bottom of the barrel .... instant circulation . There is a diagram showing proper thermosiphonm set up at the below link
http://royalcrossfarm.com/REID.html
Name:	SM Jones acmesuckerrod1902.jpg
Old 01-28-2006, 08:59 PM
Tom and Kerogas, Thanks for the replys, Jim.
Old 02-01-2006, 08:25 AM
Richard Fisher Richard Fisher is offline
Hi all; I use a big brass adjustable pressure regulator (steam?) for a pop off om my 15 HP Reid. I set it to release at 45 pounds using air and an air regulator and guage. The only time that it has ever popped off in 10 years of showing is when I lean the fuel mixture too much. I try not to do this, as it is loud.and probably hard on the engine.
Dick
Old 02-01-2006, 01:45 PM
John Burns John Burns is offline
The REID relief valve should be set at 15 lbs. I have checked the pressure on more than a few factory relief valves and none of them were set above that.
John Burns
Old 02-01-2006, 02:20 PM
kerogas's Avatar
Stuntman , Pugilist
Images: 11
Hey Burnsie !! So where did that " 0 " come from eh ? Hahaaaa !
I really dig that inside page thing you got going in GEM This month .
Got any new uniform shirts me ? Chuck Balyeat
Old 02-02-2006, 09:55 PM
Thanks Richard and John, I will print this thread and keep for when I am reassembling my Reid. I am worried that the man at at 150 psi may be headed for a broken rod. Thanks for the help. Jim
Lime in Water jacket Craig B Oil Field Engines 7 11-06-2006 12:00 PM
Water Jacket Crack Jim McIntyre Antique Gas Engine Discussion 17 01-15-2006 12:43 AM
Cracked Water Jacket Jeramea Antique Engine Archives 7 02-08-2004 11:18 PM
clogged water jacket Ed Welsh Antique Engine Archives 4 06-23-2002 01:56 PM
rust in water jacket walter Antique Engine Archives 5 05-16-2001 01:08 AM
