Welding Shop
Welding Ductile Pipe
Can anyone suggest advice on welding ductile pipe ?
this thread has 2 replies and has been viewed 1345 times
Old 02-08-2006, 01:24 PM
Dusty's Avatar
Dusty Dusty is offline
Default Welding Ductile Pipe
Old 02-08-2006, 02:13 PM
Franzİ Franzİ is offline
Registered 0
Default Re: Welding Ductile Pipe
Epoxy works best, unless you're seeking an adventure in frustration.
Old 02-09-2006, 01:06 AM
Exclamation Re: Welding Ductile Pipe
Dusty,
Ductile does not weld well, probably worse to weld than cast iron! Ductile iron for water service is extremely hard, and is also very brittle. It will tend to stress fracture after welding. I will contact the welding instructor at my union hall to see what he suggests. In the field, ductile is not welded. It is threaded and screwed, put together with mechanical joints (bell and spigot type of joint, using a rubber ring, compression ring, and lock down bolts), and or in older sections, lead and oakum caulked joints. Most of the ductile service pipe is also epoxy lined. The epoxy gives off dangerous fumes when heated. If you have 'Tru-Spun' ductile sewer pipe, it is not lined. Note - ductile is brittle stuff - It can fracture if hit with a hammer! I will get back to you with the welding info.
Welding rod Chris J Welding Shop 7 08-17-2008 11:22 AM
Casting welding Greg Shipley Antique Gas Engine Discussion 15 10-04-2006 10:07 PM
Welding Matt Fretwell Welding Shop 23 10-12-2003 08:35 AM
FANCY WELDING Eric McKenna Welding Shop 0 11-21-2002 10:36 PM
Preheat cyl before welding?? Wayne Z. Welding Shop 3 03-31-2002 11:17 PM
