Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines
Clark Bros. Engine
Hello all~ Just seeing if any one out there has any Clark Bros Engine info that they would like to...
this thread has 15 replies and has been viewed 2259 times
Old 02-11-2006, 11:05 AM
Keith Smigle's Avatar
Keith Smigle Keith Smigle is offline
Default Clark Bros. Engine
Hello all~ Just seeing if any one out there has any Clark Bros Engine info that they would like to share. I know there was an article in GEM on these engines, which month last year was that? Who is the Clark expert?
A friend of mine and I are going to rescue a 60 HP Clark pumping engine. This engine is 20 feet long, 6' flywheels and I would have to guess right around 10 to 12 thousand Lbs. A friend of our went the other day to locate the property owner so we could bet permission to remove the engine and literally saved it from the torch that very day. Here are a couple of photos
ID:	6992   Click image for larger version
ID:	6993   Click image for larger version
~Keith
Associated Mfrs Web Site
Old 02-11-2006, 11:57 AM
Doug Waggonner's Avatar
Thumbs up Re: Clark Bros. Engine
Well, I'm not an expert. But WOW! what an engine! Do both cyl's fire? Or is the one a compressor cyl? Either way, nice find!
Old 02-11-2006, 12:36 PM
Default Re: 60HP Clark Bros. Engine
The end with the large bolt around the cylinder is the compressor side. I think it just transferred natural gas, pressurizing the lines. Two rods from the cross head of the engine side go back to power the cross head of the pump side. I am just guessing but the crank main journal has to be at least 6" to 8" dia. Moving the engine and getting it running will be well documented.
~Keith
Old 02-12-2006, 10:47 AM
Where do you plan to display it? Neat find
Old 02-12-2006, 10:15 PM
Default Re: Clark Bros. Engine
This one will be shown in central Ohio. No one else out there have any Clark Literature?
~Keith
Old 02-13-2006, 06:16 PM
Keith, I'm working on trying to get you some sort of litrature on Clark engines. In a round about way Ingrasol Rand ended up with the "rights" to the Clark Engine. I have a contact there that will try looking thru their archives and hopefully find something. Please keep up posted on your progress
Old 02-13-2006, 08:11 PM
Thanks Doug~
Here is our current mindset, the engine is sitting on a hill side which is surrounded by trees. Luckily there is a small winding access road that was used by maintenance in years past. The engine will be lifted by jacks and moved onto a steel I-Beam skid and then bolted down. The engine will then be skidded off the hill side with a bull dozer to the road down below. There it will be lifted by track hoe, pipe layer, crane or some other machine with the capacity to lift this engine and it will be palced on a semi trailer frame and secured. Then the trek from Walhonding, Ohio to Radnor, Ohio. That is when the fun starts. I will keep you updated with the progress.
Thank you so much for inquiring about literature for this engine. I am also going to contact the gas company who owns the lease to see if they may still have any maintenance manuals.
~Keith
Old 02-13-2006, 09:47 PM
Gary Bahre Gary Bahre is offline
Keith; Good luck with getting the big girl up and running. When we got our 50 hp Bessie we used a oilfield truck to pick it up ( 14000 pounds or so ), he set it on a I-beam skid we built to get it home with. We also used a low- boy to haul it home, but turned the I- beam skid into a trailer to haul our engine. Nothing six or eight months of work won't take care of, keep us posted on how it is coming. Gary
Old 02-14-2006, 08:24 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 30
Lightbulb Re: Clark Bros. Engine
The Tuckahoe Steam and Gas Association has one of these engines on display in running shape. I do not know who the owner is but if you contact them, I am sure you can find out something. (http://www.tuckahoesteam.org/)
Old 02-14-2006, 04:53 PM
Don Siefker Don Siefker is offline
Smile Re: Clark Bros. Engine
[quote=Keith Smigle][font=Comic Sans MS][size=3]Hello all~ Just seeing if any one out there has any Clark Bros Engine info that they would like to share. I know there was an article in GEM on these engines, which month last year was that?
Keith,
Take a look at GEM Sept. 2005, p.9+, I think that is the article.
Don
Old 03-15-2006, 03:33 PM
Tom Adkins Tom Adkins is offline
My dad currently owns the engine that is located at Tuckahoe Steam and Gas Association in MD. He has recently restored the engine. If you have questions about the engine I can put you in contact with him.
Tom
Old 03-15-2006, 07:21 PM
Thanks Tom~
That would be great. These big engines are not all that common. I have heard there are larger Clark engines, 100HP+ but are there any left? Especially this day in age, an engine like this is seen as a recycler's dream and is quickly cut up for scrap.
~Keith
Old 09-12-2006, 02:12 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
Sorry to bump this old thread, but yes there is at least one 100+ horsepower clark engine out there.
This ol' girl was pulled out of the huntington beach ice plant. It will eventually run. Eventually...
http://gasenginerow.com/image/clark%20p4.jpg
Old 09-12-2006, 10:02 AM
Zach Williams's Avatar
Zach Williams Zach Williams is offline
I know of a place that has 2 big Clark bros engines.
I was there the last time they worked on them.
The main engine was a 120 HP double cylinder engine/compressor.
The auxillary engine was a 110 hp in the same configuration.
They just quit running them about 5 years ago.
Old 09-13-2006, 01:31 PM
agsem agsem is offline
One of our members is creating a website for our Gas Engine Row:
http://gasenginerow.com/ClarkPump.html
shows the Clark engine Eric put a picture of on here, tho on this site the HP is quoted 80 @ 200 rpm.
Here is the URL for a Clark engine that we run:
http://gasenginerow.com/Clark.html
Which is quoted at 120 HP.
Greg Hayden
Old 10-10-2006, 05:38 PM
Jim Cook Jim Cook is offline
I have 40 h.p. Clark Diesel and a 50 h.p. clark 2cycle gas. I have a copy of a manual for a clark convertable. what info are you looking for? Jim.
Clark Bros. Drilling Engine Eric M. Oil Field Engines 4 04-04-2009 03:50 AM
120 Horsepower Clark Brothers engine running at Vista, CA June 21 Eric M. Antique Gas Engine Discussion 1 07-06-2007 03:45 AM
Clark airport tug Robert Haus Antique Tractor Talk 2 06-11-2007 01:31 PM
Leroy Clark gary everett Antique Engine Archives 0 07-08-2004 06:37 PM
clark vertical L. H. Jenkins Antique Engine Archives 1 08-08-2002 10:39 PM
