Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines
Accumulator Tank Sizing
I am Lining up an Accumulator tank for a 15 hp Reid and would like to know what volume to look for....
this thread has 4 replies and has been viewed 730 times
Old 02-17-2006, 02:54 PM
Jim Gorter Jim Gorter is offline
Default Accumulator Tank Sizing
I am Lining up an Accumulator tank for a 15 hp Reid and would like to know what volume to look for. I was told at least 3 times the cylinder displacement. I have come across several small airtanks but not sure which size (volume) would be best. Thanks for any help, Jim.
Old 02-17-2006, 08:37 PM
Sharon & Jamie Sharon & Jamie is offline
Default Re: Accumulator Tank Sizing
Jim
Jamie screwed the valve out of a 20 lb propane bottle this gives you 3/4 " pipe thread. Screw in a short nipple and T. Put a line in from 100lb bottle and line out to engine. Works for us.
Sharon
Old 02-17-2006, 10:34 PM
Joel Sanderson Joel Sanderson is offline
Mine is an 8" dia. pipe about 36" long with caps welded to each end and 2" pipe fittings coming off the top near each end (it is horizontal). Seems to be working.
Old 02-18-2006, 10:51 PM
It sure wouldn't need to be 3 times the cyl displacement. The cylinder is drawing in much more air than it is propane. More like a third of cylinder displacement would be plenty I would think. Bill Klein
Old 02-18-2006, 11:05 PM
Isn't this only necessary if the engine is working and drawing a nearly full breath of gas and air? If the engine is restricted enough to run at a slow idle, can it really make a vacuum behind whatever is metering its fuel?
Sizing Safety Valves JBoogie Stationary Steam & Traction Engines 3 08-03-2007 08:08 AM
Picture re-sizing Mike Smith Antique Gas Engine Discussion 2 10-31-2005 09:55 PM
Accumulator tanks, gas-o-meter plans Jim Gorter Oil Field Engines 3 10-25-2005 03:45 PM
Picture sizing?'s Mike Smith Antique Gas Engine Discussion 2 07-22-2005 05:09 AM
Hard Core Accumulator Alan Rudd Antique Engine Archives 5 01-13-2000 10:15 AM
