Non magnetic Fairbanks MorseI have a non magnetic Fairbanks Morse 45B two cylinder marine engine with Paragon reverse gear s/n...this thread has 2 replies and has been viewed 974 times
I have a non magnetic Fairbanks Morse 45B two cylinder marine engine with Paragon reverse gear s/n 969896 rated at 25hp @ 2000 rpm. The crank shaft, flywheel, and cylinder liners appear to made of monel. The block, head, manifolds and pistons are aluminum. All fasteners are stainless steel.
The I.D. tag is a military type. Any idea what type of boat this was used in? How uncommon? I need the large timing gear, gaskets, bearings, (appears to use cleavite 77s) and a small part for one of the diesel fuel pumps. The parts all look like a standard 45B, just made out of different materials. Thanks! Joe |
I have a Fairbanks Morse 45B and a complete Operations and Parts Manual
that came with it. I, for one, would very much like to see pictures of your Twin, if you care to post some. Bruce in alaska
Could it be that this engine is from an early minesweeper?
FB |
| Magnaflux machine to charge magnetic | AllenK | Antique Gas Engine Discussion | 5 | 09-27-2007 10:49 AM |
| fairbanks morse help 1.5 za | earniemanson | Antique Gas Engine Discussion | 0 | 09-07-2006 04:49 AM |
| Need a magnetic dial indicator base | Chris Kirk | Antique Engine Archives | 3 | 09-11-2003 12:00 AM |
| 1916 Magnetic Rectifier - Info? | Don C. Wiley | Generators & Motors General Discussion | 12 | 09-23-2002 06:50 PM |
| Magnetic force | Franz | Antique Engine Archives | 2 | 10-03-2001 08:43 PM |
