Hobart Wisconsin engine...Have been given an older hobart gen/welder with a dead engine. (200A weld, 3kw gen, battery...this thread has 1 replies and has been viewed 2062 times
Have been given an older hobart gen/welder with a dead engine. (200A weld, 3kw gen, battery charger, not sure of the exact model, and its sitting 50 miles away right now) . Having some trouble determining the exact model of the engine.. Hobart doesn't have the old manuals online, the only reference I turned up to the engine model is "TUD-2", which the Wisconsin engine sites don't mention. (the closest model number mentioned is the THD, which isn't strong enough)
A saving grace, the only engine detail I actually need is the bolt circle around the output shaft. (it appears to be a trapezoid, the center hole is huge, and the welding head is single bearing upping the accuracy requirement to thou's. I would rather find an offical print than try to determine the exact center of the big hole.) |
Solved: Its not a TUD, but a TJD. Found a site selling adapter plates for pumps that had a good drawing. Turns out it is a 7.5" circle, with the top two holes 30 degrees from the centerline, the bottom two at 45 degrees. They even had the diameter of the spigot.
Now all I need is to find an apropriate hunk of 3/8 plate. |
| Hobart engine powered welder guages | John Hamilton | Welding Shop | 5 | 03-20-2008 03:23 PM |
| PE-197 Hobart Generator w/Hercules Engine questions | Joe Rambish | Generators & Motors General Discussion | 6 | 10-26-2006 12:47 PM |
| FS: Hobart Engine-driven Welder, Very Heavy Duty, in Oregon | dozer | Welding Shop | 0 | 08-05-2006 06:18 PM |
| wisconsin engine | landmagget | Antique Engine Archives | 1 | 05-08-2004 12:32 PM |
| wisconsin gas engine | frank | Antique Engine Archives | 0 | 01-06-2001 11:01 AM |
