Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Need pictures of cord saw
I'm wanting to model a small cord saw and am having trouble finding pictures of the units clear...
this thread has 7 replies and has been viewed 2313 times
Old 03-13-2006, 06:41 PM
Fred_M's Avatar
Fred_M Fred_M is offline
Email Not Working
Default Need pictures of cord saw
I'm wanting to model a small cord saw and am having trouble finding pictures of the units clear enough to build the mechanism. Any pictures will be appreciated and I may even post a picture when I'm done. LOL Fred
Old 03-13-2006, 10:45 PM
Frank Y's Avatar
Frank Y Frank Y is offline
Images: 8
Default Re: Need pictures of cord saw
Heres a pic I got off the internet a while back when I wanted to make a stand for mine but found out that the arbor shaft was rusted almost in half . Couldve been a bad situation but its a lawn ornament now.
Frank
Old 03-14-2006, 09:48 AM
Fred_M's Avatar
Email Not Working
Frank
Thanks, but that don't show the part I don't quite understand. How does the wood get fed into the blade. Don't the table tip? Hows that mechinism assembled? Fred
Old 03-14-2006, 09:47 PM
Frank Y's Avatar
Images: 8
Well its the best pic I have so I made some marks on it to highlite the tilt table. Youre right, some of the buzz saws do have the tilting table, some also had a sliding table. If you look at Rick Strobel's album of his Gal Sawrig youll see the slider. On my picture you can see where the tilting frame attaches on the far side and it also attaches to the near side but its not in the pic. The log would sit on the table, designated by the X's and then be pushed into the blade. There is also a chain that im pointing to with the arrow that holds the table from coming too far towards the operator and putting it in the loading position. You also might be able to find some better pics searching under Buzz Saw.
Old 04-01-2006, 10:58 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
This is a picture of my Ferguson AL-19 cordwood saw being run off of my 1947 Ford 2N that belonged to my grandfather. It is running in the picture. Even though it is tractor mounted, the priciples of operation are basically the same on just about all cordwood saws. On mine, the table which the wood rests on is hinged at the bottom and two springs keep the table pushed away from the blade. To cut the wood, you physically push the table into the saw blade (the table stops just short of the side of the saw so you're not actually cutting into the table). On several other tractor mounted saws and on many engine type saws, instead of being hinged, the wood table slid back and forth on tracks kinda like a kitchen drawer. I hope this helps explain how they work!
Jeb
Old 05-08-2009, 09:05 AM
hwfinn hwfinn is offline
I recently purchased a cordsaw with powered by a 4 cyclinder air cooled wisconsin engine. The blade is 32 inches in diameter. The wood lays in a rack a the rack pivots at the bottom and feeds the wood through the blade. Chains only allow the rack to move so far. I am not good at inserting pics but will e-mail them if an address becomes available
Old 05-10-2009, 06:55 PM
stumpjumper83 stumpjumper83 is offline
I know where there is one that can be had for cheap, now I dunt know about shipping but if your interested send me a pm and I'll get a price for you. its either belt or pto powered and a steel frame like the one attached to the ford n series.
Old 05-10-2009, 07:00 PM
I could also make you out a quick set of prints for it too
FM 1 1/2hp Pictures sawdusttv Magnetos, Ignition Coils and Spark Plugs 13 01-04-2008 01:25 PM
Weld pac 155 cord and gas grub54891 Welding Shop 4 08-27-2007 07:04 PM
Is 10gauge/4conductor cable ok for 60 foot generator cord? gophaster Generators & Motors General Discussion 6 05-26-2006 01:33 AM
Any pictures available? trickey Small Air Cooled Gasoline Engines 3 11-19-2005 01:09 AM
Pictures Aaron P. Antique Engine Archives 0 11-07-2002 08:15 PM
