Make and Brake Igniter contactsI have a FM JJ headless 1hp. I can only get a very weak yellow spark from the ingiter. THe...this thread has 10 replies and has been viewed 1171 times
I have a FM JJ headless 1hp. I can only get a very weak yellow spark from the ingiter. THe contact are almost gone and I was wondering what material to use to replace the contacts. Also long should the new contact be?
Scott, The best thing that I have ever found is a common nail. And the points need to be about the thickness of a nail head. Soft metal like a nail will arc better than hardend steel. Your weak spark could be something other than the points. Your magnets may need charging ,or there could be a short in the system before the current gets to the points . What kind of magneto or low tension coil are you useing? If points are made too long they will stay together too long before they open and most of the fire from the magneto and the " snap " from the spring is gone. this is more important when useing a magneto than when running on a battery and low tension coil. I hope this will help a little. Good luck in a good hobby, Joe Morris
Joe,
I appreciate you input. I will give the nail a try and see what happens. As for the coil, I'm using a 6 volt coil from a tractor. I have info on how to buils one and will give that a try as well. Thanks again Scott Bartlett |
Scott. Thanks for your reply. You might have better results useing a coil from a car , the older type tall, round ones and a 12 volt battery. Thats what has worked well for me many times. I am running a six horse F M style H useing an auto coil and a 12 volt battery. Of coarse a hand made low tension coil would be good. Joe Morris
How to you fasten the points to the ignitor?
Benny in NC
Scott: Sounds to me like you're using a high tension coil where a low tension coil should be, or am I missing something? I've never heard of running an ignitor on a car type or a buzzcoil. Kevin in Nova Scotia.
Scott: Maybe you already know this but here is a link to a page showing how to build a L/T coil
http://www.geocities.com/flywheels20...nsioncoil.html |
Thanks Joe,I have heard about what to use for points but never how to install them. Benny
Benny in NC
http://home.cybertron.com/~edurand/O...0Pictures.html Take care - Elden |
| REO contacts (HELP) | Toms Dogs | Small Air Cooled Gasoline Engines | 3 | 01-22-2008 02:03 AM |
| Buzz coil contacts | Dustin D Ehli | Antique Gas Engine Discussion | 4 | 04-24-2006 03:23 PM |
| Steam contacts in Hungary | David Parfitt | Stationary Steam & Traction Engines | 0 | 09-25-2005 01:24 PM |
| drag saw contacts | al nickelson | Antique Engine Archives | 3 | 10-15-2004 12:14 AM |
| One of those contacts sorta paid off | Paul Spence | Antique Engine Archives | 0 | 08-26-2003 04:43 PM |
