| Paint Shop Tech. Talk about paint removers, thinners, primers and application techniques plus related topics. Rust removal, paint substitutes and color matching. |
paint and gasoline reactionI think We screwed up,I'm restoring a Fairbank's morse Z,for a friend and He chose Plasti kote...this thread has 4 replies and has been viewed 1705 times
I think We screwed up,I'm restoring a Fairbank's morse Z,for a friend and He chose Plasti kote universal red # 209 engine enamal.Well after reading about paint on here i tested a small part,with gas and it came off.Dang!
If I was to use a clear coat over this that was fuel resistant will it work? I have the motor 90% painted and it would be alot of work to redo it.any info would be great! |
The problem with clear coating the existing paint are: 1) compatability - will the clear coat react with the base coat. 2) you will have to wait at least 30 days before clear coating, to allow all the volatiles to exit the base coat. 3) If the clear coat ever cracks, or takes an impact, its integrity will suffer, allowing gas to get to the base coat - this will allow the gas to penetrate and lift a large area.
4) Will the clear coat change the appearance of the base coat - change over time, and or alter with the introduction of gas to its surface (discolor)? It may be time well spent to replace bad paint now while the engine is apart, rather than later, whenyou have done all that work, and then have to redo it over. Andrew |
I can go along with that! If I paint something with RustOleum, I have to give it -at least- two weeks in warm weather to dry sufficiently to be gas resistant. Take care - Elden |
thank's,waiting for warm weather anyway, up in northern wisc, snow yet. I'm going to let it sit in the sun this spring and cure the paint .
| Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! | Harry | Antique Gas Engine Discussion | 0 | 03-14-2008 09:27 AM |
| Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! | Harry | Stationary Steam & Traction Engines | 0 | 03-14-2008 09:27 AM |
| Getting rid of old Gasoline? | Fred M. | Small Air Cooled Gasoline Engines | 13 | 12-07-2006 02:15 PM |
| gasoline | Roger Franke | Antique Engine Archives | 8 | 04-21-2003 11:39 PM |
| Personal reaction to the Personal profiles. | Dave Showerman | Antique Engine Archives | 15 | 10-30-2002 07:10 AM |
