Stubborn RustOK gentlemen here we go.... Everyone has there own concoction for for loosening rusty parts and any...this thread has 9 replies and has been viewed 6115 times
OK gentlemen here we go.... Everyone has there own concoction for for loosening rusty parts and any help would be grateful! My prference is Kroil brand oil. Has always seem to be the best. Situation----> I have two needle valves rusted in place on a carb. and been soaking them for over a month. No results? I'm afraid of putting to much tension tring to force them to open with fear they might snap off? I would then never be able to re-seat the fuel jet portion if I had to drill them out! I thought about heating to expand the metal, but were talking about cast iron? Any thoughts? Thanks a heap
I have had pretty good success boiling parts in water. I use a coleman stove and an old large sauce pan for small parts. It works amazingly well on some things. I too had a carb with a stuck needle on an Ottawa engine. The boiling did the trick. Have a large hot tank for whole engines, works well to get them free and cleaned. Use 3.5lbs of lye per gallon. I wouldn't be afraid to heat the casting with a torch, if you take it easy. I have just as good of luck using the small propane bottle torches as I do the acetaline torch. Good luck as you say it will require lots more work if you have to drill them out. What size are the needles? Are they rusted bad enough to lose some of their dimension? Hope it works for you.
Had the same problem with a couple of Fairbanks Morse duel fuel carbs. Took a weed burner and had the part hanging on a wire, heated part slowly till it just about shimmered then dunked in water. After doing this 3 times everything came off with no problem. But I heated slowly and in moderation. hope this helps Al
The electrolysis method of rust removal would be perfect for this situation, search the old methods for the process, it will not harm anything, and will go inside complicated things and between threads....works for me, and ther is no danger at all! -Bill
My preference is GIBBS all by itself for light jobs that have some looseness. Heavier jobs require "HEAT". Sometimes a lot and other times not so much. Don't melt the brass .Only problem is getting my torch outfit back(with gas left) from my son who has discovered it's wonderful use's.
Paul in NJ |
I ve used it so much over the years but it never ceases to amaze me how well electorlysis works .In fact I have had 2 buckets going continuously for the last 2 months with parts rotating in and out of the bath It is very forgiving especially on small intricate items such as those needles . I've removed many needles this way , it might however require the use of a torch for back up at the moment of truth . BY all means you should at least try it out as it really is an amazing process . And all you need is a battery charger and a handfull baking soda .
Thanks for your support gentlemen. I had some great help from the boys of the smokestak board. Gonna try 3 methods. The first one was not too successful with heating. The heat caused the solder on the thumbwheel to come off. No.2 is tonight with the electrolysis method. No. 3 will be boiling it out. Thanks again guys for your help
Another idea for you, try an electric skillet full of light oil. My dad uses used hydraulic oil about 10 weight. set the heat control to a low setting, every time you go into the shop you plug it in and unplug it when you leave. It is suprising the things that will come unstuck this way if you have the patience.
But buy your own skillet at an auction or rummage sale , so you can keep your wife happy! good luck Paul |
Here is another trick I learned....put the part in the freezer for at least 6-8 hours....bring it out and use a candle flame to heat the stuck areas...this gives a similar effect to applying torch heat, but at lower temps that will not damage things....what you want is the expansion and contraction of the metals due to the temp change, this gives it to you at lower temps...an old gunsmith's trick -Bill
if the part has been soaked in oil that has to be removed first; and once the oil has soaked into the rust it is very hard to get out without heat. For an untouched rusted part however, put it in the strongest vinegar you can get for a few days and the acetic acid in the vinegar will disolve the rust completely, right down to the bottom of the pits. If you have access to an ultrasonic cleaner, take the part out of the vinegar and suspend in the cleaner's tank, turn on and the rust (now turned to black powder) will just blow off leaving the part 'in the white'- it's quite a sight! Best method for delicate parts, doesn't spoil the heat-treating of steel or hardness of brass as heat can. Also cleans brass and other copper alloys well. For degreasing and cleaning intricate or delicate parts nothing beats a good ultrasonic cleaner either, get a good industrial soap from a janitorial supply store. "Numero Uno" works beautifully diluted with water 1 to 5.
| Stubborn Alamo | Jebaroni | Antique Gas Engine Discussion | 41 | 12-31-2007 11:32 AM |
| Stubborn Stover UPDATE!! | Greg Shipley | Antique Gas Engine Discussion | 4 | 08-22-2007 10:32 PM |
| Stubborn Stover | Greg Shipley | Antique Gas Engine Discussion | 5 | 03-18-2006 01:42 PM |
| Stubborn engine. | Greg Shipley | Antique Gas Engine Discussion | 2 | 04-06-2005 01:00 AM |
| Stubborn gibkey | Wayne Zuccarello | Antique Engine Archives | 7 | 01-21-2001 09:10 PM |
