I found this ugly, crudy coil and
bought it anyway :confused: because it was one I don't have. Now that it's refurbished, it really...
this thread has 11 replies and has been viewed 1503 times
Old 04-03-2006, 01:43 AM
Question I found this ugly, crudy coil and
bought it anyway because it was one I don't have. Now that it's refurbished, it really "LOOKS" and "WORKS" better than new? The spark adjustment can go from a slow quiet bzzzz to one that would knock your fillings out ZZZZAAAPPP. #@~&*!#? I hate when that happens. The construction of this New Way coil for an Air Cooled engine is quite substantial with its solid brass hardware. It's not cheaply made like most buzz/T type coils found by other makers. I guess I need to get an Air Cooled New Way engine to go with the coil, or something . It's "NICE" . Just thought I would share some of the fun I'm having (before and after photos), even in NJ, on the way through..........
ID:	8044   Click image for larger version
ID:	8045   Click image for larger version
ID:	8046   Click image for larger version
"OLDIHC"-Did you make a new friend today, and a lot .
Old 04-03-2006, 11:52 AM
Elden DuRand's Avatar
Images: 6
Default Re: I found this ugly, crudy coil and
Paul:
It ain't cruddy and ugly no more!
Take care - Elden
Old 04-03-2006, 06:31 PM
Paul
I have one just like it. I don't know how to test it as I have no idea what post is what.
Can you give me the the data for each post (4-2 on the side and 2 on the front) on the coil ??
Thanks,
Jim
Old 04-03-2006, 06:54 PM
Junkologist's Avatar
Images: 78
Paul,
That coil was actually made by Kingston and then sold as a New-Way accessory. I have one that is identicle, but with a Kingston decal. They are good, hot coils. You did a nice job on that one.
Mike
Old 04-03-2006, 06:57 PM
Jim Sherman's Avatar
Images: 84
http://www.old-engine.com/magbuz.htm
The posts on the top of this one may be the same as the ones on the side of the New Way coil.
"When guns are outlawed, only outlaws will have guns"
Jim Sherman
Old 04-04-2006, 12:09 AM
John Davis's Avatar
John Davis John Davis is offline
Thumbs up Re: I found this ugly, crudy coil and
Paul,
You know if you keep buying all that good! Junk! your going to have more stuff acumilating and more stuff to take care of and clean up.
Have Fun!
John
Old 04-04-2006, 12:29 AM
Images: 84
Photo Re: I found this ugly, crudy coil and
I think mine is a Kingston too but pretty much the same as the New Way coil, it's one hot coil! I had to put a new capacitor in it to make it hot....
Jim Sherman
Old 04-04-2006, 05:36 AM
Originally Posted by Jim Tremble
Paul
Thanks,
Jim
Jim: The two on the front are for the battery connections + and -. The two on the side are for the spark plug PLUG and ground. There are no markings at each of the terminals . I switched the wires around in all the possible combinations and it always worked fine ZZZZAAAPP #*^@$&*+ DARN IT OH WELL....
Old 04-04-2006, 05:41 AM
Originally Posted by John Davis
Paul,
Have Fun!
John
John: I can't stop . Not sure I want to either . Just having fun, even in NJ
Old 04-04-2006, 05:44 AM
Originally Posted by Junkologist
Paul,
Mike
Thanks Mike .
Old 04-04-2006, 10:59 AM
Jim: The two on the front are for the battery connections + and -. The two on the side are for the spark plug PLUG and ground. There are no markings at each of the terminals . I switched the wires around in all the possible combinations and it always worked fine :
Thanks,
I will wire it up as to Jim's photo. Sounds like that is what you are explaining.
Jim
Old 04-04-2006, 12:07 PM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Very NICE JOB Paul;
Well if it ever needs a new home...sure would look nice on my 4.5 hp. Paint should be going on soon.
http://community.webshots.com/album/471752277SOWnom
Regards
RickinMt.
Ugly Maytag Runs! Samuel.G Maytag Engine Collectibles 4 10-27-2007 10:07 PM
Would you buy an Ugly engine? Jebaroni Antique Gas Engine Discussion 28 10-01-2007 02:43 AM
The good, bad, and ugly truth of traction engines Rev Jim Jake Templin Stationary Steam & Traction Engines 69 06-21-2006 11:33 PM
Small "BUZZZ COIL" from parts found Paul Spence Magnetos, Ignition Coils and Spark Plugs 3 07-24-2005 04:43 PM
Aermotor "Ugly" Rocker Clone Project Elden DuRand Antique Gas Engine Discussion 2 05-30-2005 07:57 PM
