JD Magneto
I can only get a sporadic spark out of this mag even though it has a real strong magnetic pull, so...
this thread has 3 replies and has been viewed 718 times
Old 04-04-2006, 09:56 PM
Rob Leonard's Avatar
Rob Leonard Rob Leonard is offline
Default JD Magneto
I can only get a sporadic spark out of this mag even though it has a real strong magnetic pull, so I removed the leadout tower to clean the brush and removed the front cover to see how much crud was inside, I noticed that there is a small spring in a hole inside the cover, It looks like there is suppose to be a brush in there that rides against the ring?, any ideas what I could use to replace it? what would this brush be for like a ground? Thanks Rob.
Old 04-04-2006, 10:06 PM
Ironman Ironman is offline
Default Re: JD Magneto
Rob-
Yes, it IS a ground brush. A new one is available from Starbolt Engine Supplies. Go to the sponsors page and their contact information can be found there, or- wait until their banner ad cycles through and click on it.
Old 04-04-2006, 11:33 PM
Thanks for the reply Ironman. Rob
Old 04-05-2006, 12:59 AM
Exclamation Re: JD Magneto
Look carefully inside mag - you do not want that brush becoming jambed within the mag internal parts!
KW Magneto Steamrguy Antique Gas Engine Discussion 0 05-19-2005 11:39 AM
IHC 6M magneto Marty Antique Engine Archives 2 08-04-2004 05:23 PM
Magneto ID Doug Kimball Antique Engine Archives 0 01-05-2004 10:09 PM
MAGNETO A.J. TELOWICZ Antique Engine Archives 1 12-08-2002 08:01 PM
F-M Magneto Derry Nichols Antique Engine Archives 2 06-01-2001 09:20 AM
