Welding Shop
blackhawk welder
I have a mig blackhawk 220 welder that i recently bounght and i am having some problems with...
this thread has 3 replies and has been viewed 1330 times
Old 04-05-2006, 10:36 PM
CAnger CAnger is offline
Thumbs down blackhawk welder
I have a mig blackhawk 220 welder that i recently bounght and i am having some problems with it . It seems like the welder loses ground because it still feeds but doesn't weld but every now and then you will hear a click and it will work again. anyone know the problem?
Old 04-06-2006, 12:14 AM
MoRo's Avatar
MoRo MoRo is offline
Default Re: blackhawk welder
Does this happen after you've been continuously welding for awhile? If so, are you exceeding the duty cycle and tripping the breaker inside?
Old 04-07-2006, 12:59 AM
Dave Abe Dave Abe is offline
We don't have any Blackhawk welders, but have a bunch of older Miller MM200's. We've had the same thing happen on a few of the machines.
Every time it was the contactor block. It's the solenoid activated electrical connection that supplys welding power to the gun. They were easily replaceable.
Don't know if that's your problem, but a place to start.
Good luck !
Dave
Old 04-07-2006, 01:04 AM
As a side note, the contacts were able to be sanded with a bit of emery cloth and get the machine to function till the new block arrived.
Again, good luck !
Dave
Mig welder Chris P Welding Shop 8 03-23-2008 01:14 PM
Generator/welder AJH Welding Shop 4 12-02-2007 07:32 PM
Need old mig welder help!!! CAnger Welding Shop 1 11-19-2006 06:45 PM
National Cyl Gas Co. Welder ken stewart Generators & Motors General Discussion 2 05-08-2006 02:51 PM
gen/welder Tim(PA) Generators & Motors General Discussion 4 03-19-2006 02:13 AM
