Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Witte Verticle Diesel
Can anyone tell me what the Witte verticle diesel model is called. I can't even begin to research...
this thread has 9 replies and has been viewed 1473 times
Old 04-10-2006, 12:10 AM
Stans Stans is offline
Default Witte Verticle Diesel
Can anyone tell me what the Witte verticle diesel model is called. I can't even begin to research it unless I know what model it is.
stan
Old 04-10-2006, 12:27 AM
Pierce Roselle's Avatar
Pierce Roselle Pierce Roselle is offline
Default Re: Witte Verticle Diesel
stan
The single cylinder vertical dieselectric Witte is the AD. I have an exploded view and parts list for the 4 HP engine. If you would like a copy send me your address.
Pierce
Old 04-18-2006, 11:35 PM
D. Johnson D. Johnson is offline
Witte made two vertical versions of Witte engines.
Model AD, 1200/1800 rpm, 3.75/6.55 hp, 31/4 x 41/2 bore & stroke, 16:1 compression ratio.
Model LD, 1350 rpm, 8.6 hp, 41/4 x 51/4 bore & stroke, 16:1 compression ratio.
Both engines were avaliable as Power units or Dieselectric units.
Oh yes, Witte also manufactured a Marine version called the VM-59.
1200 rpm, 9 hp.41/4 x 51/4 bore & stroke, 17:1 compression ratio.
With reverse and reduction gears avalable in 2:1 and 3:1 ratios.
Hope this helps.
David Johnson
Owassoman
djoh175046@cox.net
djoh175046@aol.com
djohnson@arrowengine.com
Old 04-19-2006, 04:08 AM
ListerDiesel's Avatar
stan
I believe this is a Witte vertical diesel, pictures taken at Portland at the 2004 show:
http://www.oldengine.org/members/die...rtland4605.jpg
http://www.oldengine.org/members/die...rtland4382.jpg
Peter
Old 04-19-2006, 09:49 AM
Harry's Old Engine Site My Videos
Old 04-19-2006, 11:37 PM
Thank you for all the info gentlemen! This is indeed a wonderful forum.
stan
Old 04-21-2006, 12:48 AM
John Cunningham John Cunningham is offline
Nice pictures Harry!
I have yet to hear one of these run. I saw a horizontal at Mount PLeasant, Ia. for a couple of years now but never get to see/hear it run. Do they sound like a Thermoil??
I enjoy your site with sound samples for your engine collection.
Old 02-14-2007, 02:31 AM
Robt.'s Avatar
Robt. Robt. is offline
There are a couple of larger ones in a local scrapyard with DC gensets. They used to use them to power the magnets. Sounded like a gun going off the owner said! Massive castings too.
Old 02-15-2007, 11:41 PM
Which scrapyard would that be? Anywhere near the lower mainland?
Stan
Old 02-16-2007, 04:49 AM
Robt.'s Avatar
On the Island Stan. I don't think the engines would be much use except for parts with the in-frame DC generators.
Drop me a line if you want more info.
Witte CD diesel dieselfreakcjw Vintage Diesel Engines 3 03-12-2008 03:47 PM
Witte Diesel Tony Leonard Antique Engine Archives 16 01-10-2003 09:20 PM
witte diesel david ince Antique Engine Archives 0 12-28-2001 02:00 AM
Witte Diesel Paul Lares Generators & Motors General Discussion 1 05-19-2001 06:51 PM
